How can I use not a for but a while cycle?
How can I use not a for but a while cycle? - Mensajes
#1 Publicado: 9/2/2024 21:27:16
Valery Ochkov
Valery Ochkov
67 me gusta en 713 mensajes.
See please the attached file.Newton.sm (23,6 KiB) descargado 1629 vez(es).
#2 Publicado: 9/2/2024 23:38:00
⚜ Kenny Lemens, P.E. ᵂᴵ
85 me gusta en 181 mensajes.
Greetings,
Instead of using for(3); you can use for(4):
for ▮, ▮, ▮
The four parameter 「for(4)」 gives you the ability to loop while checking a condition. Below is the description of for( {0}, {1}, {2}, {3} )
"For loop. The function of controlled iterations. The cycle repeats {3}, while {0} satisfies the condition {1} and after each passage necessarily satisfied {2}. Repeating expressions can be set to any number of expressions."
example:
for i:=1, i<10, i:=i+2
   k:=2*i
Where 'i' starts at 1 and until i is no longer less than 10, perform operation of k:=2*i. Apply operation i:=i+2 and check if less then 10...; LOOP!
May this be of Good Help;
Valery Ochkov 10/2/2024 14:37:00
#3 Publicado: 10/2/2024 14:38:31
Valery Ochkov
Valery Ochkov
Thanks
But see "???" in the attach
Newton-for-1-2-3-4.sm (26,47 KiB) descargado 1564 vez(es).
#4 Publicado: 10/2/2024 18:38:42
StvMath
StvMath
44 me gusta y 1 no me gusta en 76 mensajes.
Here's a "while" version
Newton-for-1-2-3-4_b.sm (18,98 KiB) descargado 1617 vez(es).
Valery Ochkov 10/2/2024 19:44:00
#5 Publicado: 11/2/2024 1:58:11
As well, while associates with Bolean Critical region
Solve [Dichotomy_Newton_Secant] Copy.sm (52,75 KiB) descargado 1490 vez(es).
Valery Ochkov 11/2/2024 2:13:00
#6 Publicado: 11/2/2024 2:53:28
Valery Ochkov
Valery Ochkov
Roots vs Newton
#7 Publicado: 11/2/2024 7:55:50
oots vs Newton
No interest vs the codes
#8 Publicado: 11/2/2024 13:41:06
Valery Ochkov
Valery Ochkov
Roots vs Newton
https://www.mdpi.com/2227-7390/10/19/3413
#9 Publicado: 11/2/2024 21:59:12
roots solves Matrix.
Worksheet33.sm (6,96 KiB) descargado 1584 vez(es).
#10 Publicado: 13/2/2024 6:19:59
Grupo: Moderator
mNewton() from the Maxima plugin is another option. It also may fail for particular initial guess values.
mNewton.sm (16,22 KiB) descargado 1653 vez(es).
Alvaro 29/2/2024 12:13:00
