Beam calculation
Beam calculation - Ber7 - Mensajes
#1 Publicado: 19/11/2011 16:24:17
Fridel Selitsky
Fridel Selitsky
520 me gusta en 451 mensajes.
https://smath.com/wiki/GetFile.aspx?File=Beam.rar
Oscar Campo 19/11/2011 23:33:00
#2 Publicado: 20/11/2011 10:51:08
Fridel Selitsky
Fridel Selitsky
https://smath.com/wiki/GetFile.aspx?File=Cantilever.rar
#3 Publicado: 20/11/2011 10:51:45
Edward Ulle
Edward Ulle
21 me gusta en 182 mensajes.
Grupo: Moderator
Ber7,
You amaze me with your use of graphics in SMath. I'm a civil engineer and use SMath for calculations just like this but without the pictures.
Could you post your SMath sheet in a zip file so I can see how you do it? I don't use RAR. Thanks.
Ed
#4 Publicado: 20/11/2011 15:42:36
Fridel Selitsky
Fridel Selitsky
Ed
https://smath.com/wiki/GetFile.aspx?File=Cantileverzip.zip
https://smath.com/wiki/GetFile.aspx?File=Beamzip.zip
#5 Publicado: 20/11/2011 16:41:50
Edward Ulle
Edward Ulle
Grupo: Moderator
Ber7,
Your animations and drawings always amaze me. Thanks.
Ed
#6 Publicado: 21/11/2011 5:38:01
Fridel Selitsky
Fridel Selitsky
https://smath.com/wiki/GetFile.aspx?File=Contin%5d.zip
#7 Publicado: 24/11/2011 5:06:47
Fridel Selitsky
Fridel Selitsky
https://smath.com/wiki/GetFile.aspx?File=ElastFound.zip
#8 Publicado: 3/4/2012 19:14:42
olik
olik
3 me gusta en 27 mensajes.
Hello.
This is very nice. I am civil ingenieer & I will use it. Thanks.
However it is dangerous to use the function x>Lf.
I found it out in my own beam programming.
When changing direction of concetrated forces, the graph of shearing force has to jump once up & once down.
And for the following input it does not!
It seems to me, the function x>Lf does not work correctly each time.
Regards Olik
SMath files: beam 3 & 4.zip
Fridel Selitsky 4/4/2012 2:12:00, Andrey Ivashov 4/4/2012 2:05:00
#9 Publicado: 3/4/2012 19:20:59
kmihaylovich
kmihaylovich
8 me gusta en 131 mensajes.
Olik, try to change x>Lf to eval(x>Lf).
Fridel Selitsky 3/4/2012 22:49:00, olik 4/4/2012 13:55:00
#10 Publicado: 3/4/2012 22:52:33
Fridel Selitsky
Fridel Selitsky
Thank you, kmihaylovich, the file is corrected.
Regards,Ber7
#11 Publicado: 4/4/2012 2:04:53
Grupo: Super Administrator
Thank you! This is already fixed and will work correctly even without eval function into the next SMath Studio release.
Regards.
#12 Publicado: 4/4/2012 13:58:31
olik
olik
Thanks to all. The eval function seems to be a good way.
And if You fix this little bug, it will be the best.
Regards, Olik
#13 Publicado: 15/1/2013 13:20:31
Fridel Selitsky
Fridel Selitsky
Single moving load
AnimBeam.smz (6,25 KiB) descargado 1805 vez(es).
Davide Carpi 15/1/2013 14:02:00, Oscar Campo 15/1/2013 15:29:00
#14 Publicado: 14/2/2013 11:35:46
Fridel Selitsky
Fridel Selitsky
The load moves in deflection curve
AnimBeam1.smz (6,09 KiB) descargado 1695 vez(es).
Davide Carpi 14/2/2013 13:40:00
#15 Publicado: 20/3/2013 18:20:44
Fridel Selitsky
Fridel Selitsky
Beam on elastic foundation.Movable load
MoveEl.smz (8,49 KiB) descargado 1769 vez(es).
Davide Carpi 20/3/2013 20:58:00
#16 Publicado: 11/6/2013 5:10:10
Fridel Selitsky
Fridel Selitsky
Graphics with shading
(http://en.smath.info/forum/resource.ashx?a=1691)
AnimBeam2.sm (38,63 KiB) descargado 1661 vez(es).
A 4 usuarios les gustó este mensaje
Вячеслав Мезенцев 11/6/2013 12:00:00, ioan92 11/6/2013 5:58:00, IVR 11/6/2013 12:39:00, Davide Carpi 12/6/2013 19:18:00
#17 Publicado: 12/6/2013 11:05:41
Fridel Selitsky
Fridel Selitsky
Cantilever-new edition
https://smath.com/wiki/GetFile.aspx?File=CantileverENExe.rar
CantileverEN.smz (18,82 KiB) descargado 1822 vez(es).
ioan92 3/7/2013 16:23:00, Davide Carpi 12/6/2013 19:19:00
#18 Publicado: 2/7/2013 15:55:17
Fridel Selitsky
Fridel Selitsky
Beam with a variable distance between the supports
BemAnim.smz (15,6 KiB) descargado 1701 vez(es).
ioan92 3/7/2013 16:23:00, Andrey Ivashov 3/7/2013 17:19:00, Davide Carpi 2/7/2013 16:44:00
#19 Publicado: 6/7/2013 14:29:47
Fridel Selitsky
Fridel Selitsky
Analysis of statically indeterminate beam. Supported cantilever.
Beam fixed at the one end supported an the other
https://smath.com/wiki/GetFile.aspx?File=Konsol%2bopora.rar
Konsol+opora.smz (134,15 KiB) descargado 1808 vez(es).
IVR 7/7/2013 14:46:00, Davide Carpi 6/7/2013 18:31:00
#20 Publicado: 11/2/2021 3:32:36
Egidijus
Egidijus
0 me gusta en 2 mensajes.
Hello, could somebody help me. I don't understand how to solwe this problem.
