1 páginas (7 elementos)
Vectors creation with ranged indices - How to use vectors with subscripts (by typing: [) - Mensajes
Does anyone know how to use vectors with subscripts (by typing: [) in SMAth as I have done in the attached Mathcad file (.pdf + .xmcd). I have tried it in SMath (see the attached SMath file) but this does not work in the same way. Does anyone knows a workaround?
Best regards,
Rens Servais
Archivo no encontrado.Archivo no encontrado.Archivo no encontrado.
Best regards,
Rens Servais
Hello Rens,
You can do it in the same way, but indices here are base 1 instead of base 0
SMath file (r1).sm (4,53 KiB) descargado 1207 vez(es).
![2018-03-21 14_55_53-SMath Studio - [SMath file (r1).sm_].png](/es-ES/files/Download/rZcxyq/2018-03-21-14_55_53-SMath-Studio---[SMath-file-(r1).sm_].png)
Thanks a lot Davide!
Rens
Rens
Reminded me of a loop I had for Mathcad. Somehow, the equal sign is not correct and not working. A little help? Range2Vec program.smz (2,93 KiB) descargado 1280 vez(es).
WroteReminded me of a loop I had for Mathcad. Somehow, the equal sign is not correct and not working. A little help? Range2Vec program.smz (2,93 KiB) descargado 1280 vez(es).
What would be the expected result?
You had Count as subscript instead of index in the loop.
Wrong subscript ... Fixed Range2Vec.smz (3,31 KiB) descargado 1311 vez(es).
