Graphs for the control tasks
Graphs for the control tasks - graph from point to point - Mensajes
#1 Publicado: 25/5/2021 15:56:39
Renzo Choque
Renzo Choque
6 me gusta en 18 mensajes.
Hi, I want to set my label to vertical dimension but when I rotate the text it gets distorted, please how can I fix it?
#2 Publicado: 26/2/2023 13:23:18
TopUser2000
TopUser2000
0 me gusta en 28 mensajes.
Hello.
Tell me, please, if I have two points, then how can I plot a graph between them? According to my assignment, I need to build several graphs, but I do not know how to do it in the program. I have done the calculations, but for the rest I ask for help from local experts. I attach a sheet with the task and a file with calculations (sorry, that's in Russian). Can someone help me figure it out here?
DPT s NV.sm (19,52 KiB) descargado 1394 vez(es).
Mekhanicheskie kharakteristiki DPT s nezavisimym vozbuzhdeniem.docx (95,56 KiB) descargado 708 vez(es).
#3 Publicado: 26/2/2023 14:31:43
Grupo: Moderator
I made a sample with two different plots.
You can use them by changing variables.
DPT_NV plot.sm (11,08 KiB) descargado 1354 vez(es).
TopUser2000 26/2/2023 15:06:00
#4 Publicado: 26/2/2023 17:33:26
TwoPointsPlot.sm (11,84 KiB) descargado 1336 vez(es).
TopUser2000 27/2/2023 5:03:00
#5 Publicado: 26/2/2023 21:09:46
#6 Publicado: 26/2/2023 21:21:08
Grupo: Moderator
You can also use line and polyline commands for plot.
They work only in XYPlot, but sometimes they make everything easy.
There is also a setprop() function.
It can change format of your XYPlot automatically.
Search setprop() in forum for further information.
DPT_NV plot.sm (20,47 KiB) descargado 1515 vez(es).
#7 Publicado: 27/2/2023 4:54:30
TopUser2000
TopUser2000
Thanks to everyone. The first answer helped me enough)
One more question:
if I have a graph (attached file), then how do I mark the points along which it passes?
I tried: vector M(s) ω(s) "." 15 "blue"
but the application immediately crashes.
AD.sm (20,17 KiB) descargado 1310 vez(es).
Is it possible to make the graph automatically scale to the new values?
And does someone use android version of Smath (from this site)? I can't edit any of these files there.
#8 Publicado: 27/2/2023 8:47:08
If I have a graph (attached file), then how do I mark the points along which it passes?
As in the attached.
Instead of re-scaling the same graph, plots all new graph on the same plot.
You will scale to accommodate for the larger graph.
AD Plot Points.sm (104,39 KiB) descargado 1388 vez(es).
TopUser2000 27/2/2023 15:08:00
#9 Publicado: 27/2/2023 11:29:43
TopUser2000
TopUser2000
I'm afraid it's too difficult for me)
Is there any simple way to add the pass points and autoscale a graph?
#10 Publicado: 27/2/2023 13:38:10
Some Smath versions decided that opening in other versions will be black.
1. Open this document
2. If black, select by groups, click on background white
3. Make the all document as per 2. directive
4. at this point, you have recovered my original
5. Plot points and more advanced.
AD Plot Points TopUser2000.sm (87,24 KiB) descargado 1324 vez(es).
#11 Publicado: 27/2/2023 13:57:37
Grupo: Moderator
You can use this, XYPlot region is suitable.
One custom function to plot everything.
It also autoscale the graph.
AD.sm (28,23 KiB) descargado 1286 vez(es).
#12 Publicado: 27/2/2023 15:09:51
TopUser2000
TopUser2000
Oh... What literature can I read about making plots in?
#13 Publicado: 27/2/2023 16:42:23
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
Нужно в YouTube в поиске набрать: SMath Studio tutorial и применить фильтр плейлистов. Там найдётся около 4-5 видеокурсов. Можно отфильтровать по продолжительности.
Также каждый дополнительный компонент (расширение) имеет здесь на форуме свою тему, где в начале обычно приложены примеры типового использования.
#14 Publicado: 27/2/2023 16:47:58
TopUser2000
TopUser2000
Тут вроде самый необходимый минимум мне описали, но, казалось бы, простую задачу, когда на графике надо проставить точки, тут описывают каким-то сложным для меня способом. Причем, среди кучи текста непонятно, что именно отвечает за эти точки.
Да и с автомасштабом графика я так и не понял.
#15 Publicado: 27/2/2023 16:51:27
Grupo: Moderator
По точкам нужно просто посмотреть примеры использования графиков.
setprop() - функция устанавливает свойство компонента. Возвращает 1, если свойство найдено и успешно установлено, иначе 0.
Она ищет компоненты на всех листах с указанным именем и меняет указанное свойство. Набор доступных для изменения свойств ограничен.
Точки также можно включить в свойствах кривой. ПКМ на компоненте и выбрать настройки, далее зайти в свойства кривой и там выбрать тип маркеров вместо пустого.
В компоненте XYPlot нет автомасштаба, поэтому пока так.
#16 Publicado: 27/2/2023 16:51:55
Oh... What literature can I read about making plots in ?
Download first document @ post 10 ... let's see if it works ?
#17 Publicado: 27/2/2023 17:04:02
Grupo: Moderator
This is what uni cleverly mentioned.
Which I totally forgot its existence.
The plot
Traces
Styles
Вячеслав Мезенцев 27/2/2023 17:05:00, TopUser2000 2/3/2023 4:30:00
#18 Publicado: 2/3/2023 4:32:18
TopUser2000
TopUser2000
Now it works but anyway this way is too difficult for me
#19 Publicado: 2/3/2023 13:46:49
Glad it works from doctoring the black.
Nothing is too difficult for Smath Community to which you now belongs.
Your very first document, populate more for standard reference project.
If you just have some experimental points you can't escape Hermite.
It was used long time ago for Mollier.
Hermite cubic interpolation is more ancient than my Mathcad 8 Pro.
Take care ... Jean
TopUser2000 5/3/2023 13:02:00
