1 páginas (14 elementos)
solve & roots with units - Mensajes
WroteI can it solve in Mathcad - see please mcdx and pdf files
I try solve it (heat transfer) in SMath - see sm file
Help please
SMath symbolic solving of integration is not capable as Mathcad.
Thus integrals can't be used with numeric solvers.
However, you can use a little trick to solve them.
Using maple or maxima plugins is the key.
Here is your problem solved with various ways, roots() and Findroot().
solvewithunits.sm (23,4 KiB) descargado 1419 vez(es).
Hi. The attached have an al_nleqsol wrapper for a Mathcad block with units, that can accept SMath's integrals too.
Kerimov-Cvetkov-Velichko-1-7 - nSol.sm (17,97 KiB) descargado 1454 vez(es).
Hello Valery,
In some application(s), you can associate FindRoot with epsilon.
Solve Diophantine Chemical Balance epsilon.sm (106,1 KiB) descargado 1486 vez(es).
Valery Ochkov 5/6/2023 11:26:00
Please help, why can't find root for this simple equation?
Archivo no encontrado.Archivo no encontrado.
root.sm (20,2 KiB) descargado 1389 vez(es).
WrotePlease help,
why can't find root for this simple equation ?
roots solves wrt scalar function(s)
In this example, both functions are scalar wrt 'x'.
Try ... roots[(sin(x)-Gamma(x),x,1]
'x not defined' ... Gamma(x) is not scalar wrt 'x'
Few more numerical functions are not scalar
erf(x), erf(x,n) ... erfc(x), erfc(x,n) ...
WroteTry ... roots[(sin(x)-Gamma(x),x,1]
In that case and similar ones,
RootSecant algorithm will spits out 15 decimals, instantaneous.
WroteWrotewhy can't find root for this simple equation?
Because there aren't unknows
Thanks Davide.
Now I put "N" as unknown in the Eq. But it can't be solved either.
root.sm (19,41 KiB) descargado 1358 vez(es).
You have to play a little with the precision, especially if there are units involved; in this case, seems that 10^-3 mm is a stable target (10^-2 works too, but in some case it returns the guess value, meaning that is "close enough" for the algorithm - you can see in the plot that 0kN to 200kN is in +0.02/-0.02mm range)
![2023-06-26 15_55_45-SMath Solver - [root_r1.sm].png](/es-ES/files/Download/KcnuBb/2023-06-26-15_55_45-SMath-Solver---[root_r1.sm].png)
root_r1.sm (24,03 KiB) descargado 1426 vez(es).
netsonicyxf 26/6/2023 12:18:00
![2023-06-26 10_49_28-SMath Solver - [root.sm_].png](/es-ES/files/Download/M4RRUF/2023-06-26-10_49_28-SMath-Solver---[root.sm_].png)
