error in a system of equations
error in a system of equations - impossible to get or set an item because it does not exist - Mensajes
#1 Publicado: 5/11/2019 14:02:37
Ale16595
Ale16595
0 me gusta en 35 mensajes.
Hi to everyone
I am having difficulty solving a linear system like in the picture.
the error says:"impossible to get or set an item because it does not exist"
does anyone know where the error can be and how to solve this problem?
Thanks in advance
#2 Publicado: 5/11/2019 15:08:12
127 me gusta en 342 mensajes.
"roots" does not work with the units. You must adimensionare equations, or you can try the other features present in the plugin (eg "FindRoot" present "Nonlinear solvers" plugin)
#3 Publicado: 5/11/2019 15:52:23
Ale16595
Ale16595
I tried another function but it still gives me an error...
#4 Publicado: 5/11/2019 23:57:28
It's a huge system, and generally does not accept all initials same.
I would zap units first. This kind of solving should have it be
solved from P & P [Pain & Prestige] as it reflects real project
that does come out of the blue. Even Mathcad Given/Find may fail
or pedal through constrain.
Attach the work sheet ... some source reference as well.
#5 Publicado: 6/11/2019 2:25:20
Ale16595
Ale16595
here is the spreadsheet
calcoli.sm (46,18 KiB) descargado 1170 vez(es).
it is a system of equations derived from the condition of dynamic equilibrium in the stationary curve motion of a bicycle
#6 Publicado: 6/11/2019 4:16:32
Grupo: Moderator
Equations 3 and 4 probably demand different values for N.r+N.f So there is no solution.
If the system has a solution, the function Solve() from Maxima plugin might find it.
sergio 6/11/2019 6:47:00
#7 Publicado: 6/11/2019 15:20:34
1. equalities [1,2,3] are consistant 'N'
2. equalities [4,5,6] are inconsistant 'mixed units'
calcoli.sm (52,58 KiB) descargado 1120 vez(es).
You must make the system consitant before attempting solve.
#8 Publicado: 6/11/2019 15:35:50
Ale16595
Ale16595
I tried to use the solve function but it still gives me an error saying that S is not defined
#9 Publicado: 6/11/2019 15:47:31
Did you read my reply just before your visit ?
#10 Publicado: 6/11/2019 16:20:21
Ale16595
Ale16595
sorry, when I wrote, I didn't notice your message
#11 Publicado: 10/11/2019 23:11:18
Hi. Try this setup, using al_ library. I don't know if using better guess values can get better results (eqn 3 and 4 don't get good results)
calcoli.sm (50,31 KiB) descargado 1168 vez(es).
#12 Publicado: 11/11/2019 7:37:20
Ale16595
Ale16595
Hi, thanks for the reply, but I think I found the error. The system I wrote has two linearly dependent equations, and for this reason it cannot find a solution.
I will have to modify the whole problem.
#13 Publicado: 11/11/2019 14:55:47
Hello Alvaro,
The attached CSTR [SS 6179] example is offered differently,
it is initialized from random guesses: success.
Solve al_nleqsolve CSTR.sm (38,81 KiB) descargado 1150 vez(es).
Alvaro 12/11/2019 13:29:00
#14 Publicado: 12/11/2019 13:29:59
Hello Alvaro,
Hi Jean. Thanks, very interesting.
