need help
need help - Mensajes
#1 Publicado: 9/5/2026 8:35:16
Andreas Beldowski
Andreas Beldowski
0 me gusta en 17 mensajes.
unfortunately, I can't find the error myself. Why VS(t) and VRG58(t) work well, but V1(t):=VS(t)-VRG58(t) not?
Regards Andreas
Auszug.pdf (114,69 KiB) descargado 395 vez(es).
Auszug.sm (16,52 KiB) descargado 511 vez(es).
#2 Publicado: 9/5/2026 9:14:00
127 me gusta en 342 mensajes.
It seems that the two quantities have different units of measurement.
#3 Publicado: 9/5/2026 12:44:41
Andreas Beldowski
Andreas Beldowski
Thanks Sergio,
wrong was VRG58(t):=Ig(t)*(1/ZLRG58+1/RRG58)
right is VRG58(t):=Ig(t)*(ZLRG58+RRG58)
Regards Andreas
#4 Publicado: 10/5/2026 5:52:13
Andreas Beldowski
Andreas Beldowski
and here’s another problem. Why does the differential of V1(t) work, but not that of V2(t)?
Both are sine functions; later, I’d like to try using square-wave functions as input as well.
For V1 and V2, I need the peak-to-peak amplitude and the phase difference between the two. I want to see if I can get better approximations for determining C1 by taking RG58 and the probe tip’s internal resistance into account in the measurement results.
Regards Andreas
Translation of “Der Wert ist oberhalb der maximalen Grenze für positive Zahlen” = “The value is above the maximum limit for positive numbers”
Versuch mit R und C mit Oszi.pdf (982,36 KiB) descargado 352 vez(es). The value is above the maximum limit for positive numbers.gif Versuch mit R und C mit Oszi.sm (131,13 KiB) descargado 518 vez(es).
Editado 10/5/2026 6:01:03
#5 Publicado: 10/5/2026 8:15:12
StvMath
StvMath
44 me gusta y 1 no me gusta en 76 mensajes.
"Why does the differential of V1(t) work, but not that of V2(t)?"
It's a combination of the size of the numbers and the order in which SMath does its calculations. Try:
#6 Publicado: 10/5/2026 10:41:34
Andreas Beldowski
Andreas Beldowski
Yeah, that's how it works for me, too.
#7 Publicado: 12/5/2026 13:09:32
Andreas Beldowski
Andreas Beldowski
It's me again, with a new problem.
Why doesn't the last line work, when the four lines above it do?
Versuch mit R und C mit Oszi Auszug.gif Versuch mit R und C mit Oszi Auszug.pdf (910,43 KiB) descargado 340 vez(es). Versuch mit R und C mit Oszi Auszug.sm (130,35 KiB) descargado 495 vez(es).
#8 Publicado: 13/5/2026 2:13:04
Hi. I have no idea why it fails, however this may be a workaround, consisting of directly applying the Newton-Raphson method.
Versuch mit R und C mit Oszi Auszug.sm (121,16 KiB) descargado 483 vez(es).
#9 Publicado: 13/5/2026 5:47:01
Andreas Beldowski
Andreas Beldowski
And why can I only use the values for LV1 and LV2 once, but the values for LdV1dt and LdV2dt multiple times?
I had already deleted the `clear()` statements, but that wasn't the problem.
Editado 13/5/2026 5:48:52
#10 Publicado: 13/5/2026 9:41:38
Hi. Use eval:
