1 páginas (6 elementos)
imaginary unit - Mensajes
Can we have another imaginary unit?
an "i" with two vertical lines?
When I solve electric circuit problems I have to use "c" for current.
Thank you,
Basile
Thank you,
Basile
Thank you Jean.
I believe that a code solution is needed for i, π, e, etc.
Basile
Basile
WroteI believe that a code solution is needed for i, π, e, etc.
You are correct, you shouldn't redefine some constants globally by editing a setting file.
Only option is adding variable defining codes to start of your worksheet.
