imaginary unit
imaginary unit - Сообщения
#1 Опубликовано: 19.03.2023 10:07:20
Basile
Basile
8 сообщений из 172 понравились пользователям.
Can we have another imaginary unit?
an "i" with two vertical lines?
When I solve electric circuit problems I have to use "c" for current.
Thank you,
Basile
#2 Опубликовано: 19.03.2023 17:06:03
an "i" with two vertical lines ?
Like this Basile ... Cheers Jean
#3 Опубликовано: 19.03.2023 17:09:09
Basile.sm (3,66 КиБ) скачан 1236 раз(а).
#4 Опубликовано: 19.03.2023 21:48:45
Basile
Basile
Thank you Jean.
I believe that a code solution is needed for i, π, e, etc.
Basile
#5 Опубликовано: 20.03.2023 07:22:34
Thank you Jean.
Basile
I don't vote to freak 'e, π'
Like ... sin(x)^2 ► sin²(x)
#6 Опубликовано: 21.03.2023 07:25:44
You are correct, you shouldn't redefine some constants globally by editing a setting file.
Only option is adding variable defining codes to start of your worksheet.
