1 páginas (14 elementos)
Summation Equivalent - Mensajes
Still cant get it to work, I will strip out the identifying material and post the worksheet.
Thanks
Ian
Thanks
Ian
Attached is sheet, this is a MRM for beam frequency analysis
natural freq 5 v2 forum.sm (58,25 KiB) descargado 1346 vez(es).
WroteAttached is sheet, this is a MRM for beam frequency analysis
Sum over 'n' ... NOT over 'k'
Model summation attached.
Function Running Summation.sm (32,66 KiB) descargado 1337 vez(es).
Better to attach the original Mathcad document.
Mathcad sheet attached, striped version
beam frequency test 2.xmcd (171,06 KiB) descargado 1317 vez(es).
Jean, I am at a loss as to which part of your file I should be looking at.
Ian
Ian
Hi. As Viacheslav says, it's better in this case the mathcad file. Just a couple of notes.
You use a for loop with i as counter. Thus, at the exit, i equals the last count value, not the entire range. So, or you redefine i as range, or use this way for not changing i value
Actually, SMath doesn't have "range" variables, it only have scalars and matrices. But mathcad have "true" range variables, which it's more a complication than an adventage. BTW in SMath you can't use a range variable in the same way, and sometimes needs some dummy variable for detect them
Finally, remember that in mathcad sqrt(-1) is 1i, but in SMath it is just i, so using is as counter you loose all the complex algebra.
Bests regards.
Bests regards.
WroteJean, I am at a loss as to which part of your file I should be looking at.
It just shows how to run summation wrt several dependent functions.
Hi Alvaro,
Some interesting hints there. I imagine its also the same going the other way.
Hi Jean,
OK, now I understand, just some pointers for me
Thanks
Ian
Hi Jean,
Thanks
Ian
WroteHi Jean,
Thanks
Ian
The A,B are numerical two vectors of coefficients.
Then introduced in the scalar function wrt sin/cos.
WroteI am trying to convert a Mathcad 15 sheet, and have a problem with the below equation:
I think that there should be such a replacement.
Archivo no encontrado. Archivo no encontrado.
