1 páginas (3 elementos)
Print .exe files - Problems to print a .exe SMath file made in old version - Mensajes
Hi! I´ve been facing some problems to print a .exe SMath made in a old version.
I have installed in my computer the latest stable version (0.99 6884) and when I try to print the file appears an error message of gdi+ generic error.
The only issue is this, despite this, I can use the file without other problems.
Do you know how can I fix it? I´m not sure in which SMath version it has been made, I only know that it was in a old version.
The only way you have is to generate a new executable using a more recent SMath Studio. Once an executable is created it is independent from any installed applications and/or plugins; this means that you don't need SMath Studio when you run the executable, and also that every feature (as well as any bug) will stay in that executable forever.
WroteThe only way you have is to generate a new executable using a more recent SMath Studio. Once an executable is created it is independent from any installed applications and/or plugins; this means that you don't need SMath Studio when you run the executable, and also that every feature (as well as any bug) will stay in that executable forever.
Thanks!
