Print .exe files
Print .exe files - Problems to print a .exe SMath file made in old version - Сообщения
#1 Опубликовано: 01.02.2019 07:36:32
Hugo Gatti
Hugo Gatti
Hi! I´ve been facing some problems to print a .exe SMath made in a old version.
I have installed in my computer the latest stable version (0.99 6884) and when I try to print the file appears an error message of gdi+ generic error.
The only issue is this, despite this, I can use the file without other problems.
Do you know how can I fix it? I´m not sure in which SMath version it has been made, I only know that it was in a old version.
#2 Опубликовано: 01.02.2019 10:50:26
The only way you have is to generate a new executable using a more recent SMath Studio. Once an executable is created it is independent from any installed applications and/or plugins; this means that you don't need SMath Studio when you run the executable, and also that every feature (as well as any bug) will stay in that executable forever.
#3 Опубликовано: 01.02.2019 11:27:33
Hugo Gatti
Hugo Gatti
Thanks!
