numeric display
numeric display - numeric display - Mensajes
#1 Publicado: 26/3/2024 22:36:24
TopUser2000
TopUser2000
0 me gusta en 28 mensajes.
Hello. Tell me, please, is it possible to see the set numerical values when calculating formulas in the program? I mean, instead
of
a = 5, b = 6,
a + b = 11
see a = 5, b = 6,
a + b = 5 + 6 = 11
#2 Publicado: 27/3/2024 9:21:28
churichuro
churichuro
29 me gusta en 79 mensajes.
test1.sm (5,06 KiB) descargado 1533 vez(es).
#3 Publicado: 27/3/2024 16:56:37
TopUser2000
TopUser2000
In the simplest case, this option would be suitable, but if the formula is a little more complicated, then we get a pile of fractions and numbers
#4 Publicado: 28/3/2024 19:54:32
Arie
Arie
94 me gusta en 285 mensajes.
FYI there has been some discussion about this feature in the past.
https://en.smath.com/forum/yaf_postst23575_Substitution-Optimization.aspx
Also a function proposed here: https://en.smath.com/forum/yaf_postsm78024_substitute-variables.aspx#post78024
#5 Publicado: 28/3/2024 23:26:08
TopUser2000
TopUser2000
FYI there has been some discussion about this featurein the past.
https://en.smath.com/for...tution-Optimization.aspx
Also a function proposed here: https://en.smath.com/for...variables.aspx#post78024
But there is no solution for this request there...
#6 Publicado: 29/3/2024 2:29:38
Grupo: Moderator
There is also this topic.
https://en.smath.com/forum/yaf_postst21565_Show-values.aspx
What you seek is won't be simple, as you requested and applicable however.
This situation is explained in detail by mkraska at the link above.
#7 Publicado: 29/3/2024 11:58:56
⚜ Kenny Lemens, P.E. ᵂᴵ
85 me gusta en 181 mensajes.
Greetings,
Alvaro has built a function to address this feature request:
Note: it has a little bit of a learning curve, but is worth considering never-the-less.
May this be of Good Help;
#8 Publicado: 30/3/2024 1:40:58
TopUser2000
TopUser2000
I don't see the result in the attached screenshots of how it works. A jumble of formulas where there is no clear answer.
