1 páginas (15 elementos)
Vibrations of membranes - Mensajes
Vibrations of a circular membrane.The axisymmetric case
Solution are described with the help of Bessel functions .
https://en.wikipedia.org/wiki/Vibrations_of_a_circular_membrane
Bessel'2.sm (29,66 KiB) descargado 1559 vez(es).
Tanks Ber7: saved in your named file.
Vibrations of a rectangular membrane
Calculation formulas are taken from the book:S.Timoshenko,
Vibration Problems In Engineering
MemPl.sm (14,03 KiB) descargado 1482 vez(es).
Archivo no encontrado.Archivo no encontrado.
Deflection of simply supported equilateral triangular plate
The plate rests on a frame in the form of an equilateral triangle.
The triangular part of the plate is loaded uniformly distributed
load. The equation of the surface of deflections of a triangular plate is taken
from the book of S.P.Timoshenko.Timoshenko S.P., Woinowsky-Krieger S. Theory of plates and shells. New York, NY: McGraw-Hill; 1959.
triangular plate.sm (12,86 KiB) descargado 1457 vez(es).
Andrey Ivashov 24/1/2018 16:37:00, Davide Carpi 19/1/2018 20:26:00, NDTM Amarasekera 19/1/2018 22:43:00
Thanks Ber7 for that one and the other one few days ago.
WroteI tried to use the plugin Maxima
Thanks Ber7, I love those 3D, though it will never beat Mathcad 8... 11.
On my own, I published several times more than the entire Mathcad Community.
I don't miss them in Smath 6179, why ? purely useless for the Engineer.
They are just for the Gallery [Tom G. would say Peanut Gallery].
We are just waiting for a stable Smath version delivered with Maxima plugin
and more of the possible plugins. Scilab looks far superior to Maxima ?
Deflection of a Circular Plate.Plate contains rigid
inclusion of radius b and loaded at the Center
(Timoshenko,S.and Woinowsky-Krieger, S.,Theory of plates and shells, 1959)
Inclusion.sm (32,68 KiB) descargado 1481 vez(es).
Davide Carpi 29/1/2018 7:29:00
Hello Beer7, is this vibration of a rectangular membrane equivalent to the deflection of a simply supported, uniformly loaded, rectangular plate? (leaving aside the physical parameters like plate thickness, Young's modulus etc.) I am only interested in the curvature on various locations on the surface, not in absolute values (max deflection can be calculated using simple civil engineering formulaes).
Thanks,
Laurent
Thanks,
Laurent
WroteVibrations of a rectangular membrane
WroteVibrations of a circular membrane.The axis symmetric case
Solutions are described with the help of Bessel functions .
Thanks Ber7, works great. Beautiful work.
mwbesselj(0,x) is ~ 4 times faster 15 decimals
Hart JZERO 5852 is 23 decimals up to ± 8.
Bessel JY.sm (75,19 KiB) descargado 1442 vez(es).
What happened, your previous post is gone with the wind ???
Try this, so much faster !
Bessel mwbesselj Membrane Ber7 [20190126].sm (31,26 KiB) descargado 1335 vez(es).
Vibrations of a triangular membrane
Calculation formulas are taken from thearticle:
http://ivdon.ru/uploads/article/pdf/IVD_44__1_Chernyshov.pdf_30f490557a.pdf
Vibration triangular membrane.sm (319,69 KiB) descargado 1429 vez(es).
Alvaro 4/1/2021 12:30:00
Thanks, works fine after doctoring CreateMesh.
Vibrations of a triangular membrane(Maxima)
TriangularMembrane Maxima.sm (279,28 KiB) descargado 1534 vez(es).
.png)
