1 páginas (6 elementos)
Fourier transform - Mathcad Fourier transform doesn't work in SMath - Mensajes
Dear all,
I have a Mathcad Document about Fourier transform that I want to translate into SMath.
I already dowloaded the FFTPack plugin. I used the same functions from the Mathcad document which doesn't work in SMath.
I tried a bit but nothing is working. The error message says "The argument must be a scalar."
I attached screenshots from my SMath document and the original Mathcad document.
Does anyone have an idea or a helpful tip?
Thanks in advance
Thanks in advance
Thank you! That worked and the error message is gone.
I'm still having trouble plotting the graph. The graph is not being displayed but there isn't any error message.
Did I overlook something? Does the rfft() function work different in SMath than in Mathcad?
Thanks in advance
Thanks in advance
Check if it can help you. The graph has the correct shape but the values are different.fft_spalt_test(sergio).sm (10,62 KiB) descargado 514 vez(es).
Caro 15/5/2026 16:30:00
