CoolProp Wrapper
CoolProp Wrapper - Pure and pseudo-pure fluid equations of state and transport properties for 122 components - Mensajes
#61 Publicado: 21/4/2023 15:17:35
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
How can I get properties of mixtures e.g
CoolProp_Props("Dmass","T",273+100,"P",101.3*10^3,"Helium[0.5]&Xenon[0.5]"
ref: http://www.coolprop.org/fluid_properties/Mixtures.html
This can't be done directly in the current version of the plugin. It is not clear how to call the apply_simple_mixing_rule() function from the library, it can't be imported as it is not in the export table.
Click to enlarge
Click to enlarge
maple-python-coolprop.sm (6,61 KiB) descargado 1955 vez(es).
maple-python-coolprop.pdf (19,18 KiB) descargado 1381 vez(es).
Click to enlarge
maple-python-coolprop-2.sm (5,08 KiB) descargado 1912 vez(es).
#62 Publicado: 22/4/2023 5:00:09
Hi. Notice that Refprop from NIST can't handle He/Xe mixing either. At least version 9.
On the other hand, maple doesn't seem to implement the procedure that Viacheslav points out either, as can be seen in the online documentation for the latest version.
However, very good values can be obtained using Coolprop in SMath and some basic stoichiometry.
Mixing gases.sm (19,17 KiB) descargado 1904 vez(es).
Mixing gases.pdf (67,22 KiB) descargado 1282 vez(es).
#63 Publicado: 22/4/2023 5:34:44
Grupo: Moderator
More simple
Click to enlarge Click to enlarge Click to enlarge
maple-python-coolprop-3.sm (10,97 KiB) descargado 1918 vez(es).
maple-python-coolprop-3.1.sm (10,82 KiB) descargado 1909 vez(es).
maple-python-coolprop-3.2.sm (10,89 KiB) descargado 1822 vez(es).
Alvaro 22/4/2023 9:32:00
#64 Publicado: 27/4/2023 3:09:34
Grupo: Moderator
Now you can write like this
maple-python-coolprop-3.3.sm (9,51 KiB) descargado 1921 vez(es).
#65 Publicado: 28/4/2023 7:39:13
Grupo: Moderator
Or like this
maple-python-coolprop-3.4.sm (10,66 KiB) descargado 1925 vez(es).
maple-python-coolprop-3.5.sm (10,3 KiB) descargado 1887 vez(es).
#66 Publicado: 29/4/2023 15:33:10
Grupo: Moderator
Click to enlarge
maple-python-coolprop-3.6.sm (9,98 KiB) descargado 1869 vez(es).
#67 Publicado: 29/4/2023 22:07:03
churichuro
churichuro
29 me gusta en 79 mensajes.
is fantastic!
this no work the first time but after I play with the another examples this work, very well
thank you!
#68 Publicado: 4/5/2023 10:29:17
Grupo: Moderator
Without "pyfile" (inline multiline script). The script should be without comments.
Space padding is necessary here so that inside the script, when a large string is divided into parts, the line break character itself is not divided ( '\n' -> '\ n' ).
maple-python-coolprop-3.7.sm (9,9 KiB) descargado 1914 vez(es).
maple-python-coolprop-3.8.sm (6,84 KiB) descargado 1911 vez(es).
maple-python-coolprop-3.9.sm (8 KiB) descargado 1876 vez(es).
#69 Publicado: 30/7/2023 8:12:32
usamakhan
usamakhan
7 me gusta en 97 mensajes.
Uni, can you please help me how to add python into SMATH, I have python already in system [WinPython 3.9] How I link it up with Smath?
I have working CoolProp
#70 Publicado: 30/7/2023 13:33:42
usamakhan
usamakhan
Jean, can you help me how do integrate python in my Smath? I event tried environmental variables under Win10 but didn't work
#71 Publicado: 31/7/2023 3:45:32
Grupo: Moderator
You should use a double slash for the full path.
In this case, you need to check whether python is available from the command line. If not, it means that the paths are specified incorrectly.
#72 Publicado: 2/8/2023 19:17:11
usamakhan
usamakhan
uni, thanks a lot
Can you tell me what is this block you used after python sub-section [i.e with the square bracket & holding script conetnts]
Additionally Razonar sample here is also very intuitive while calculating mixing values
https://en.smath.com/forum/yaf_postsm82120_Understanding-Redlich-Kwong-equation-of-state.aspx#post82120
#73 Publicado: 3/8/2023 3:06:16
Grupo: Moderator
uni, thanks a lot
Mathcad Block from the Mathcad Toolbox plugin and just Text inside it for the script.
#74 Publicado: 4/8/2023 15:23:07
usamakhan
usamakhan
uni, so it means the text inside the block is not automatically generated. Can you please explain the construct
On second note you were correct, I fixed my environment variable under windows %python% now works
#75 Publicado: 8/8/2023 2:01:18
Phase diagrams with CoolProps.
Click to enlarge
PhaseDiagram.sm (39,17 KiB) descargado 1915 vez(es).
Davide Carpi 8/8/2023 2:10:00
#76 Publicado: 9/8/2023 3:47:50
Psychrometric Chart with CoolProps. 'Simplified' version (more readable): Enthalpy lines overlap web bulb temperature lines.
Click to enlarge
PsychrometricChart.sm (125,39 KiB) descargado 1878 vez(es).
#77 Publicado: 21/8/2023 17:39:50
usamakhan
usamakhan
I think I have found some problems while using plugin to get phase properties as discussed here: http://www.coolprop.org/coolprop/HighLevelAPI.html#imposing-the-phase-optional
First when using "P|phase_gas" it doesn't accept units & T,P values have to be directly written in SI equivalent
Second there is a value discrepancy when using "P" & "P|phase_gas" for a fluid that exists only in gas phase at that T,P
Archivo no encontrado.Archivo no encontrado.
#78 Publicado: 16/4/2024 3:55:20
Grupo: Moderator
It seems that multiple instances of SMath can't use the plugin at the same time.
How to reproduce:
1. Open SMath and access any Coolprop function
2. Open another SMath instance: You get an error message
#79 Publicado: 19/12/2025 1:10:36
Phase diagrams with CoolProps. ...
Now can show other thermo properties, and get animations.
PhaseDiagram.sm (46,88 KiB) descargado 877 vez(es).
Animating volume of water and enthalpy of O2.
Вячеслав Мезенцев 19/12/2025 18:44:49, Valery Ochkov 23/6/2026 8:27:38
#80 Publicado: 12/8/2026 21:45:52
Nate Brown
Nate Brown
0 me gusta en 1 mensajes.
I have a small feature request that I may be in the wrong spot to make. Anyway, I love how the CoolProp Wrapper is able to keep track of units and it's way more convenient than Excel or Python. Today I noticed that the wrapper is currently unable to handle units for derivatives. For example, the syntax of CoolProp_Props("d(C)/d(T)|P", "T", 300 K, "P", 1 atm, "Water") results in -0.3248 unitless. By doing a central difference around the same temperature with constant pressure, SMath+CoolProp will respond with -0.3248 J/kg·K². Is there a way that we can get the units into the shorter syntax?
