CoolProp Wrapper - Pure and pseudo-pure fluid equations of state and transport properties for 122 components - Mensajes
WroteDynamic assistance is enabled in the program's options?
С уважением,
Михаил Каганский
Davide Carpi 26/10/2016 6:50:00
WroteHello Jean, according with CoolProp documentation "Q" stands for "Mass vapor quality", thus 1 is 1 mol/mol
Thanks Davide for "unitless Q" and the link to CoolProp Wrapper
Davide Carpi 26/10/2016 12:50:00
Thanks, Davide!
It's fixed indeed.
It's fixed indeed.
С уважением,
Михаил Каганский
A german smath user contacted me and asked me to include the steamtable dll for EFI in the portable distribution. They weren't included in the recent update because this involves some additional config work and I assumed that the coolprop wrapper might be a replacement.
According to the mentioned user, the steamtables are of better accuracy than the coolprop functions. Thus I now updated the portable distribution.
The user also asked for speed of sound and isentropic exponent functions. Is there a way to help him?
WroteThe user also asked for speed of sound and isentropic exponent functions. Is there a way to help him?
"WASP" is freeware for 10 minutes use, unlimited sessions.
"WASP" from "Katmar". all properties are tabulated per T(°C) or P(abs).
As for the speed of sound can be accessed using "A" or "speed_of_sound"
![2017-01-07 17_36_28-SMath Studio - [CoolProp_demo.sm_].png](/es-ES/files/Download/UAUwTU/2017-01-07-17_36_28-SMath-Studio---[CoolProp_demo.sm_].png)
For the isentropic functions I googled "isentropic coolprop" and there is something but it is not my field, maybe Mike can give some hints.
Hello
On entering >>CoolProp_Props("D","T",298.15*K,"P",10*bar,"CO2")=<< I receive a message "K not defined;
Are the double quotes correct?
Tim
Tim
Hello Tim,
You missed the units character (apostrophe) before K and bar -> 'K, 'bar
CoolProp_Props("D","T",298.15*'K,"P",10*'bar,"CO2")
![2017-05-17 00_36_10-SMath Studio - [Page1_].png](/es-ES/files/Download/s8ZADx/2017-05-17-00_36_10-SMath-Studio---[Page1_].png)
WroteOn entering >>CoolProp_Props("D","T",298.15*K,"P",10*bar,"CO2")=<< I receive a message "K not defined;
Hello Davide,
Thank you for looking into my issue.
I had indeed overlooked the apostrophe, thank you.
I copy and pasted your coolprops statement into SMath but I don't get an answer, instead a red border around the statement.
I also typed the statement in from fresh and I get the same.
Is the ordinary >> = << used on a coolprops statement? Will the answer appear before units are applied to the result?
What is the most simple test to see coolprops working?
Tim
Tim
What's the error message now?
Simplest way to check if it might works should be:
Also, here there are 3 worksheets to run as test
CoolProp_get_global_param_string("version"
which versions of SMath and CoolProp plugin are you using?
Wrotewhat's the problem?
There may be two issues:
1. WASP is awfully involved in Basic construction. I coded it in Mathcad 11
Get the Katmar WASP [very complete] free for 2 min session, unlimited sessions.
2. The published Basic is unitless, the CoolProp is unit based,
that is enough to freaked the codes. The Mathcad version from Valery was OK.
Sorry, can't help more.
Error:
Error message couldn't be retrieved from CoolProp library (buffer size issue?); the second try returned:
version SMath - 0.98(build 6484)
version CoolProp -
I'm try on the various Windows platforms (32/64):
good result on
Win10x64Pro, Win7x64Ultim
don't working on
Win10x86Pro, Win10x86Educ, Win7x86Pro
Best regards,
Aleksey
Wrotewhich versions of SMath and CoolProp plugin are you using?
version CoolProp -
good result on
don't working on
Best regards,
Aleksey
Davide Carpi 27/12/2017 12:43:00
This is just a comment.
Assume my firm knows nothing about Smath and you are doing a project for us
and the project requires be tracable and you would use CoolProp-Wrapper.
If you can't prove it is certified, it won't pass QA.
CoolProp-Wrapper would be rejected [as simple as that].
IMHO, from this thread, CoolProp must be doctored regardless of the
Win version and/or Smath version.
Wrotedon't working on
Thank you, reproduced. Something goes wrong with the wrapped 32 bit library (the coolprop dll returns both the correct result as well as an error code, hence the errors shown).
is it possible to run it on ubuntu 17.10 using mono?, I can't get it to work, when I try to evaluate "CoolProp_get_global_param_string("version")" I just get a little yellow message under the command that reads "CoolProp_x64", or do I need to compile the coolprop binaries ins some specific folder or is it a standalone plugin-extension?
![2016-10-26 10_04_52-SMath Studio 0.98.6128 - [Page1].png](/es-ES/files/Download/ybBZyh/2016-10-26-10_04_52-SMath-Studio-0.98.6128---[Page1].png)
