CoolProp Wrapper - Pure and pseudo-pure fluid equations of state and transport properties for 122 components - Сообщения
WroteHow can I get properties of mixtures e.g
ref: http://www.coolprop.org/fluid_properties/Mixtures.htmlCoolProp_Props("Dmass","T",273+100,"P",101.3*10^3,"Helium[0.5]&Xenon[0.5]"
This can't be done directly in the current version of the plugin. It is not clear how to call the apply_simple_mixing_rule() function from the library, it can't be imported as it is not in the export table.
maple-python-coolprop.sm (6,61 КиБ) скачан 1963 раз(а).
maple-python-coolprop.pdf (19,18 КиБ) скачан 1388 раз(а).
maple-python-coolprop-2.sm (5,08 КиБ) скачан 1920 раз(а).
Hi. Notice that Refprop from NIST can't handle He/Xe mixing either. At least version 9.
On the other hand, maple doesn't seem to implement the procedure that Viacheslav points out either, as can be seen in the online documentation for the latest version.
However, very good values can be obtained using Coolprop in SMath and some basic stoichiometry.
Mixing gases.sm (19,17 КиБ) скачан 1912 раз(а).
Mixing gases.pdf (67,22 КиБ) скачан 1297 раз(а).
More simple
maple-python-coolprop-3.sm (10,97 КиБ) скачан 1925 раз(а).
maple-python-coolprop-3.1.sm (10,82 КиБ) скачан 1921 раз(а).
maple-python-coolprop-3.2.sm (10,89 КиБ) скачан 1830 раз(а).
Alvaro 22.04.2023 09:32:00
Or like this
maple-python-coolprop-3.4.sm (10,66 КиБ) скачан 1934 раз(а).
maple-python-coolprop-3.5.sm (10,3 КиБ) скачан 1894 раз(а).
is fantastic!
this no work the first time but after I play with the another examples this work, very well
thank you!
thank you!
Without "pyfile" (inline multiline script). The script should be without comments.
Space padding is necessary here so that inside the script, when a large string is divided into parts, the line break character itself is not divided ( '\n' -> '\ n' ).
maple-python-coolprop-3.7.sm (9,9 КиБ) скачан 1922 раз(а).
maple-python-coolprop-3.8.sm (6,84 КиБ) скачан 1919 раз(а).
maple-python-coolprop-3.9.sm (8 КиБ) скачан 1884 раз(а).
Jean, can you help me how do integrate python in my Smath? I event tried environmental variables under Win10 but didn't work
You should use a double slash for the full path.
In this case, you need to check whether python is available from the command line. If not, it means that the paths are specified incorrectly.
WroteI event tried environmental variables under Win10 but didn't work
uni, thanks a lot
Can you tell me what is this block you used after python sub-section [i.e with the square bracket & holding script conetnts]
Additionally Razonar sample here is also very intuitive while calculating mixing values
https://en.smath.com/forum/yaf_postsm82120_Understanding-Redlich-Kwong-equation-of-state.aspx#post82120
uni, so it means the text inside the block is not automatically generated. Can you please explain the construct
On second note you were correct, I fixed my environment variable under windows %python% now works
Psychrometric Chart with CoolProps. 'Simplified' version (more readable): Enthalpy lines overlap web bulb temperature lines.
PsychrometricChart.sm (125,39 КиБ) скачан 1885 раз(а).
I think I have found some problems while using plugin to get phase properties as discussed here: http://www.coolprop.org/coolprop/HighLevelAPI.html#imposing-the-phase-optional
First when using "P|phase_gas" it doesn't accept units & T,P values have to be directly written in SI equivalent
Second there is a value discrepancy when using "P" & "P|phase_gas" for a fluid that exists only in gas phase at that T,P
WrotePhase diagrams with CoolProps. ...
Now can show other thermo properties, and get animations.
PhaseDiagram.sm (46,88 КиБ) скачан 885 раз(а).
Animating volume of water and enthalpy of O2.
I have a small feature request that I may be in the wrong spot to make. Anyway, I love how the CoolProp Wrapper is able to keep track of units and it's way more convenient than Excel or Python. Today I noticed that the wrapper is currently unable to handle units for derivatives. For example, the syntax of CoolProp_Props("d(C)/d(T)|P", "T", 300 K, "P", 1 atm, "Water") results in -0.3248 unitless. By doing a central difference around the same temperature with constant pressure, SMath+CoolProp will respond with -0.3248 J/kg·K². Is there a way that we can get the units into the shorter syntax?
