find and replace
find and replace - Mensajes
#1 Publicado: 9/4/2019 13:49:30
The Cross
The Cross
0 me gusta en 73 mensajes.
Is there a find and replace function for formulas? Example, you have a bunch of formulas that have a subscript of 11 in variables, and you want to change all of the 11's to 3's?
#2 Publicado: 9/4/2019 15:20:26
Grupo: Moderator
Yes.
In a single math region, you can use the F8 key an you'll be able to rename all local variables/functions at once.
Globally, you can do it with the Text Region Utilities plugin.
#3 Publicado: 9/4/2019 15:27:40
The Cross
The Cross
In a text region, nothing happens if I push "F8". Also, I have the text region utilities plugin on SMath, but don't know how to access it in the sheets. Also, I was also asking how to do this in an actual formula, not a text region.
#4 Publicado: 9/4/2019 15:34:12
Grupo: Moderator
True, edited.
Go to "Insert" > "Text region utilities" > "Toolbox"
This will add a small region in the worksheet. Right clik on the region to access the "Search and replace" dialog. You might have to evaluate the worksheet to make it working properly.
Both F8 and the TRU dialog are able to do that, just play with the options (uncheck "Text regions", check meaningful math options).
#5 Publicado: 9/4/2019 15:39:46
The Cross
The Cross
Do the above apply to version 0.99 (build: 7005)? our computer people have not updated to the current version.
#6 Publicado: 9/4/2019 15:48:07
The Cross
The Cross
I don't see a "toolbox" under "text region utilities". Also, what do you mean by "evaluate the worksheet"?
#7 Publicado: 9/4/2019 15:57:02
Grupo: Moderator
It's the third item: "Insert a toolbox"
TRU
Perform a calculation of the whole worksheet.
You can do it by pressing F9 or with the menu option "Calculation" > "Recalculate page" or using the green "refresh arrows" in the toolbar.
#8 Publicado: 9/4/2019 16:02:04
subscript(s) as number is pest. In general, subscripts just confuse
unless they are for didactic demo. If you have literal subscript(s)
it might then be easier to change via text.
.... example mnemonic ...type 'J' thermocouple in the range up 356 °C
J_356(mV):=f(x,b)
#9 Publicado: 9/4/2019 16:09:46
The Cross
The Cross
TRU
In my pulldown, there is nothing below "text region", except for "region protection"
#10 Publicado: 9/4/2019 16:25:57
Grupo: Moderator
It's an old screenshot, unfortunately I'm from smartphone and I can't make an actual one.
However since a while items in insert menu are sorted by type (folders then simple items) and by name a to z, if you have it should be one of last folders
#11 Publicado: 9/4/2019 16:29:58
The Cross
The Cross
"insert a toolbox" or toolbox, is not there, as far as I can see.
#12 Publicado: 9/4/2019 16:50:46
Grupo: Moderator
Then go to tools > plugins, and with the top right button set as "local storage" check if the plugin is in the list.
If it's there and disabled, you can enable it again.
If is missing, change the top button to "online gallery" and you can install it from the list.
#13 Publicado: 9/4/2019 16:58:38
The Cross
The Cross
I don't know what is going on, because, the "standard ToolboxButtons" addin is there, and enabled, but it does not come in on the pulldown menu under insert.
#14 Publicado: 9/4/2019 17:42:14
Arie
Arie
94 me gusta en 285 mensajes.
It may be necessary to restart SMath if you just installed Text Region Utilities.
#15 Publicado: 9/4/2019 17:45:11
The Cross
The Cross
I installed it about 3 weeks ago, and have restarted the computer every day since.
#16 Publicado: 9/4/2019 18:35:10
Grupo: Moderator
"Standard Toolbox Buttons" is the built-in plugin that handles the callapsible palettes on the right of the screen (Arithmetic, Matrices, Booleans, etc...)
Text region Utilities is a different addin and provides (even) the "toolbox region".
If you search "text" in your extensions manager and you have the plugin installed you should see something like this (SS 0.99.7005):
#17 Publicado: 17/4/2019 12:45:05
The Cross
The Cross
I have Text Region Utilities now. Is there a way to use search and replace to just search a selected portion of the worksheet, and not search the whole worksheet? Can I select a certain portion of the worksheet and have SMath search and replace for just the selected area?
#18 Publicado: 17/4/2019 18:20:10
Grupo: Moderator
Not as for now.
#19 Publicado: 17/4/2019 21:24:59
Something like in Google search reporting all Lagrange highlighted yellow
from some books in PDF ... thus reporting all regions containing Lagrange
in an Smath document. Or otherwise search for π in math regions ?
By portion: Do you mean page range of several pageswork sheet ?
or in displayed on screen ?
Long Smath work sheet of several pages are rare as they soon suffer
from shadow in context [dog chasing his own tail].
