The problem with the function of the vector
The problem with the function of the vector - Mensajes
#1 Publicado: 7/4/2020 11:49:26
Andrey007
Andrey007
0 me gusta en 7 mensajes.
Please help with the prZadanie 2.sm (9,86 KiB) descargado 1453 vez(es).oblem. For some reason, the program does not like the range j, why it is not clear.
Thanks for the help
#2 Publicado: 7/4/2020 16:16:24
Andrey007
Andrey007
Archivo no encontrado.
Please help with the prArchivo no encontrado.oblem. For some reason, the program does not like the range j, why it is not clear.
Thanks for the help
#3 Publicado: 7/4/2020 16:19:22
Andrey007
Andrey007
#4 Publicado: 7/4/2020 19:47:33
Grupo: Moderator
Hello [userlink]Andrey007[/userlink]
Here there is your code adaped to SS syntax.
To loop the (scalar) functions through the values of a vector (1-column matrix) you can use vectorize or a for/while function.
Since in A=0 Kg(A) is indeterminate (0/0) and Kn(a) is an infinity and you can't plot that I've started the range from the 2nd value within the original range.
Zadanie 2_1.sm (12,66 KiB) descargado 1449 vez(es).
#5 Publicado: 8/4/2020 9:29:23
Sorry for some gross mistake ... deleted.
You can use Smath code floor/ceiling
Zadanie 2_1[floor].sm (15,05 KiB) descargado 1266 vez(es).
#6 Publicado: 8/4/2020 17:48:42
Andrey007
Andrey007
Thanks for the help, be healthy!
