1 páginas (3 elementos)
Working Random Var [Compendium] - Working Random Var [Compendium] - Mensajes
Enrich your projects with this starter.
Random Signum.sm (17,88 KiB) descargado 1574 vez(es).
Random Stem Style.sm (15,54 KiB) descargado 1518 vez(es).
Random more.sm (22,5 KiB) descargado 1566 vez(es).
Randon Bin [Stem].sm (20,15 KiB) descargado 1290 vez(es).
Randon Bin.sm (58,31 KiB) descargado 1514 vez(es).
Randon Segment Circular Shapes.sm (38,25 KiB) descargado 1581 vez(es).
Random UnitCircle.sm (40,22 KiB) descargado 1513 vez(es).
Random [rnd(n)].sm (55,55 KiB) descargado 1302 vez(es).
Random Fill Range PDF.sm (991,43 KiB) descargado 1588 vez(es).
Very nice examples Jean, as usual
The last file (where you presented the "fill" matrix - a large matrix in the gray area to the right) is an example where it might get you troubled. You can get red crossed box with Critical error, or at least the message "Object not set to an instance of an object". I think that you also mentioned this in some other examples. Presenting large matrices might be quite troublesome in SMath (although there are some plugins regarding this problem).
WrotePresenting large matrices might be quite troublesome in SMath
Radovan.
_______________________
That is true sometimes for unknown reason. And the worst is that it might work during
contruction, but zap on re-opening ! Other times it fails transmission. The "while"
looks solid in that respect. I tried many times 2000 points ... fine.
I'm used to these kind of problem from Mathcad. Sometimes the project is scrapped for
ever. We did the "Courant Surge" project for ITER [Cadarache], one of the data table
got lot and I have no more contact. It was not really a table, rather data:=
apparently less risky but evaporated. Crappy stuff gets transmitted as well.
Keep working hard 2016.
