1 páginas (7 elementos)
Double Integration using ode solvers - Mensajes
Hi. This worksheet shows how to use an ode solver for evaluating a double integral over the region between two functions.
DoubleIntegralRK.sm (42,67 KiB) descargado 1444 vez(es).
DoubleIntegralRK.pdf (219,12 KiB) descargado 1011 vez(es).
Thanks Alvaro for your example.
Can the change of variable be put in the procedure definition?
Physics is like sex. Sure, it may give some practical results, but that’s not why we do it. (R. Feynman)
WroteCan the change of variable be put in the procedure definition,?
Like this: yes, just opposite plot.
Double Switch [x, L].sm (6,33 KiB) descargado 1160 vez(es).
Hi. This is the double integral using Gauss Legendre quadrature.
GaussLegendreQuadrature.sm (60,58 KiB) descargado 1443 vez(es).
GaussLegendreQuadrature.pdf (160,77 KiB) descargado 1018 vez(es).
Yes.
DoubleIntegralSteelCat.sm (47,08 KiB) descargado 1411 vez(es).
DoubleIntegralSteelCat.pdf (105,49 KiB) descargado 834 vez(es).
Wrote...
Yes.
Keisan has longer Legendre than 64, but couldn't copy/paste ?
From other source: 63, 64.
Integrate Legendre [ Wr 24 ].sm (28,98 KiB) descargado 1189 vez(es).
WroteKeisan has longer Legendre than 64, but couldn't copy/paste ?
Hi Jean. Yes, can copy and paste. Do that first into excel, and from there to the small SMathMatrixEditor and finally paste in SMath.
In the attached Laguerre and Legendre coeffs for the Gauss method.
DoubleIntegralJean.sm (25,63 KiB) descargado 1379 vez(es).
DoubleIntegralJean.pdf (45,11 KiB) descargado 929 vez(es).
WroteHi Jean. Yes, can copy and paste.
Thanks, Amigo !
