Measurment units bug? - Can't add degreeC to the variable - Mensajes
I found some strange behaviour. Let's assume two dimensionless quantity length:=10 and temp:=12. Now I multiply length * 1m and the result is 10m. However if I multiply temp * 1degC the result is error because temp is not defined? Is it some kind of a bug?
https://ibb.co/B2203KY
WroteHello everyone!
I checked and it's really strange
It is enough to type: temp*'°C=
Wrotewhy you type an additional "'" between temp and °C ?
To make the unit silent but responding.
Had been used/demonstrated ad nauseum.
Most useful in program, still conveying meaning.
It's a trickier way to make things work (why use this "trick" with Celsius Degrees but not with Meters?)
A little exaggerated affirmation...and not documented on common help documents (Interactive Guide, Handbooks, nor wiki)
WroteA little exaggerated affirmation...and not documented on common help documents (Interactive Guide, Handbooks, nor wiki)
The two you mention are little fraction of all Forum projects.
Silent unit is not documented as wellroot that works superb.
However, silent is coded ... otherwise would cry to murder !
I like you Oscar, take care ... Jean.
WroteIt looks like a bug to me. Is there a chance that it will be fixed any time soon? What do you think? Will use "'" between temp and °C for now...
Yep! I agree. I just reported the issue in bug section of the forum.
Regards!
WroteWroteA little exaggerated affirmation...and not documented on common help documents (Interactive Guide, Handbooks, nor wiki)
The ‘silent unit’ is only mentioned by you only in 5 topics (this is only 5 or 6 posts) in the entire forum, and nobody discussed about it, so, here, in this forum, there is not enough documentation about it either there is not information about it on SMath Interctive Guide, SMath Handbooks, nor SMath Wiki
The ‘silent unit’ is not the question in this topic.
The issue originally mentioned by Porschaka looks like a bug, so it was reported in the corresponding section.
The conversion for these 3 units is not linear, meaning you can't just multiply by a factor to get the conversion.
If you are only planning on working with your own isolated units without taking advantage of the built in units, then go right ahead and define a custom version of the unit.
This issue needs to be solved in the programing or with a custom function that does the conversion for you the right way and can handle the nonlinear units.
WroteThe issue originally mentioned by Porschaka looks like a bug,
OK Oscar, explain to yourself what the unit should be:
10m*1°C ... Ask SI Community.
Eager to discover ... Jean.
You assign unit to undefined,
do it otherwise: put °C in result.
That's not the point of discussion. Please check the original post.
WroteJean, please don't spam the topic with irrelevant information...
You are right: Carlos has doctored your red image.
Reynolds is one more doctored for Engineers
... for Smath Community as profitable.
WroteYou are right: Carlos has doctored your red image.
![2021-09-16 15_09_34-SMath Solver - [Worksheet1_].png](/es-ES/files/Download/FouD6M/2021-09-16-15_09_34-SMath-Solver---[Worksheet1_].png)
