[SS-3567] File corrupted after using region protection option
[SS-3567] File corrupted after using region protection option - Mensajes
#1 Publicado: 3/10/2018 13:07:21
cecile
cecile
0 me gusta en 7 mensajes.
I used protection regions on my smath sheet. Everything went fine until I close the sheet and try to reopen it. I can't expand areas no more (no "+" or "-" available anymore at the begining of the area), nor can I run calculations...
The file seems corrupted. It weights only 20kB...
Someone help please!
File is available here :corrupted file.sm (20,13 KiB) descargado 1450 vez(es)..
Thanks a lot
#2 Publicado: 3/10/2018 14:28:12
Grupo: Moderator
Confirmed and reproduced; (also, reproducible using copy and paste on opened worksheets).
Unfortunately everything in the protected area is lost (not saved, hence not recoverable).
Bug reported as SS-3567.
#3 Publicado: 4/10/2018 4:24:57
cecile
cecile
Thank you for having a look at it anyway.
#4 Publicado: 4/10/2018 7:05:14
Grupo: Moderator
Thank you for reporting; as posted in the BTS the issue is fixed now and will be part of the next release.
#5 Publicado: 14/7/2022 23:21:58
oscar mauricio
oscar mauricio
1 me gusta en 10 mensajes.
Hi, I find a similar error when I use region protection and secondary areas are contained in the area.
When opening the sheet all content is protected
I hope it could be improved in future versions.
