Unable to open sm file
Unable to open sm file - Mensajes
#1 Publicado: 26/2/2021 13:52:59
NDTM Amarasekera
NDTM Amarasekera
130 me gusta en 352 mensajes.
While making finishing touches to the attached SM file (latest version), a warning message
propped up to continue or quit. I continued, saved and closed.
But now unable to open it. It loads but immediately closes without any message.
Can this be recovered please?
This is the first time I came across this type of an issue.
I use latest WIN 10 64 bit Home edition
TEST.sm (387,7 KiB) descargado 1660 vez(es).
#2 Publicado: 26/2/2021 14:22:14
Grupo: Moderator
For information, same behavior with bug under Linux.
Seems a line break is written wrong to file.
Corrected it with text editor and tried to save under smath to replicate the bug.
Couldn't achieve to bug reappear again.
Code was like this previously.
<p><br>EE</br>Calculate the head losses and the corrected fows in the various pipes of a </p>
Revised to this with text editor.
<p>EE<br />Calculate the head losses and the corrected fows in the various pipes of a</p>
TEST_rcv.sm (488,99 KiB) descargado 1685 vez(es).
#3 Publicado: 26/2/2021 14:41:00
NDTM Amarasekera
NDTM Amarasekera
Corrected it and tried to save to replicate the bug.
Thank you very much for your contribution.
It saved me a lot of trouble.
#4 Publicado: 26/2/2021 21:01:16
Grupo: Moderator
You are welcome, happy to help you.
#5 Publicado: 27/2/2021 12:18:02
Ruben Sidranski
Ruben Sidranski
17 me gusta en 465 mensajes.
I've had this issue before. Thanks for the fix, the last time this happened, I had a backup. The funny thing is, per HTML code, the first screenshot looks "more" correct.
NDTM, I spotted what appears to be minor spelling error. FLOWS, not FOWS
#6 Publicado: 27/2/2021 12:30:47
NDTM Amarasekera
NDTM Amarasekera
Yes. Thank you. Now I made the correction.
#7 Publicado: 1/3/2021 1:31:58
NDTM Amarasekera
NDTM Amarasekera
Whenever I try to edit contents of some description boxes the unhandled exception error message props up. For information of Developers please.
#8 Publicado: 1/3/2021 7:41:53
Grupo: Moderator
Please attache the content of the "Details" window.
IDK I'm only an amateur HTML coder but to me
always has been a void/empty element; looking at standards:
In the orginal HTML (up to 4.01) only
is correct;
In XHTML
and
are allowed,
is not allowed.
In HTML 5 only
and
are allowed,
is not allowed.
something
was newer allowed, so it seems an encoding bug to me.
#9 Publicado: 1/3/2021 12:25:09
NDTM Amarasekera
NDTM Amarasekera
Details Window.txt (30,14 KiB) descargado 1268 vez(es).
Pipe_Network_EX_HARDY_CROSS.sm (299,12 KiB) descargado 1565 vez(es).
#10 Publicado: 4/3/2021 8:53:47
Grupo: Super Administrator
Both issues fixed. Thank you!
#11 Publicado: 5/3/2021 13:45:27
NDTM Amarasekera
NDTM Amarasekera
Thank you Andrey!
#12 Publicado: 25/3/2021 10:21:12
JenniferCastillo
JenniferCastillo
0 me gusta en 4 mensajes.
Most accurate and informative answer.
