loop for routine
loop for routine - Mensajes
#1 Publicado: 23/5/2014 19:24:24
ingciv
ingciv
0 me gusta en 4 mensajes.
Hello:
I need help with this routine. I created a loop with while function, but it takes too long in finding a solution.
I think code its OK, but I dont know the software limitations... (I programmed the same in scilab and worked well)
Thanks in advance.
Ultimate Strength Analysis_v0.0.sm (32,39 KiB) descargado 1479 vez(es).
#2 Publicado: 24/5/2014 2:23:18
Grupo: Moderator
It seems (not sure) that your code does not change the exit loop condition and you are in infinite loop - see the picture please.
#3 Publicado: 24/5/2014 14:24:07
ingciv
ingciv
But why?? I tried to use a for loop, but it's the same result. First I thougth it was because of the units, so I take them away from the matrixes, but now I'm running out of ideas...
I tried doing a second loop, without for or while, but again the same...
Ultimate Strength Analysis_4.1.sm (44,76 KiB) descargado 1453 vez(es).
#4 Publicado: 24/5/2014 16:55:39
Grupo: Moderator
at the end of iteration, nothing changes. iteration means values you start with have to change for the next iteration. same values are being used in every iteration. same aux is being calculated every time. the loop can not end this way. at the end, i am saying the same thing that omorr have said i hope i could help.
#5 Publicado: 24/5/2014 17:06:19
Grupo: Moderator
If you set all regions to optimization> numeric (in the context menu, after marking them all with Ctrl-A), then I see no problems in the attachment 4.1.
#6 Publicado: 24/5/2014 17:38:16
ingciv
ingciv
you were rigth, i forgot to redefine xIC_ini in the last else... thanks
#7 Publicado: 24/5/2014 17:43:21
ingciv
ingciv
THANKS, it was the optimization method, everithing works fine with numeric
#8 Publicado: 25/5/2014 2:10:20
Grupo: Moderator
One more example related to Numerical-Symbolical optimization. There were already many of them here on the Forum. Just to remember that Martin proposed the Numerical optimization should be the default one - not the Symbolical. On the other hand, regarding the way Smath is working I have the impression that this will not be possible and this situation of Symbolic optimization used by default will remain. Am I right about it, or not ???
