Double pendulum
Double pendulum - Mensajes
#1 Publicado: 20/9/2026 10:08:09
Valery Ochkov
Valery Ochkov
67 me gusta en 713 mensajes.
I feel the model is not correct - help please!
Pendulum-2-animation.sm (22,59 KiB) descargado 296 vez(es).
Editado 20/9/2026 10:09:28
#2 Publicado: 21/9/2026 11:02:24
Hi Valery. The system is coupled. This is a way to solve it.
double_pendulum_lagrangian.sm (122,44 KiB) descargado 301 vez(es).
double_pendulum_lagrangian.pdf (637,78 KiB) descargado 244 vez(es).
ioan92 9/10/2026 19:34:51, Valery Ochkov 21/9/2026 16:39:03
#3 Publicado: 21/9/2026 14:02:10
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
Yes, that is correct; I previously reported on the limitations regarding the systems.
The algorithm does not currently classify the task, so issues may arise with complex problems that the current method cannot solve. It might produce a plausible-looking solution that does not actually address the problem at hand.
#4 Publicado: 21/9/2026 16:47:18
Valery Ochkov
Valery Ochkov
Thanks, Alvaro.
It reminds me of an old joke.
A funeral. A passerby asks, "Who are they burying?"
"That guy lying in the coffin."
That was a mathematician's answer—completely accurate and completely useless.
Mathcad 15
Editado 21/9/2026 16:53:09
#5 Publicado: 22/9/2026 10:43:08
If mathematics is a tautology, then life must be one too. That joke reminds me of the one a plant process engineer played on me when I went to get the bourdon gauge I was supposed to install. Without a word, he handed me a brown box. That was when I have the bad idea of asking what was inside. His answer was that it contained a mechanical device that measures fluid pressure using a curved, flattened metal tube that straightens as internal pressure increases, driving an indicator needle across a calibrated dial.
The RKA function includes the necessary procedures to solve hard coupled systems.
double_pendulum_RKA.pdf (483,53 KiB) descargado 243 vez(es).
double_pendulum_RKA.sm (43,57 KiB) descargado 305 vez(es).
ioan92 9/10/2026 19:38:29, Valery Ochkov 22/9/2026 12:25:43
#6 Publicado: 8/10/2026 11:18:22
Valery Ochkov
Valery Ochkov
Thanks, Alvaro!
But I cannnot create five f(t) plots:
Potential energy of pendulum #1
Kynetic energy of pendulum #1
Potential energy of pendulum #2
Kynetic energy of pendulum #2
Sum of energies for the verify the model and ODEs solver. Must be const.
Help please!
Editado 8/10/2026 11:18:52
#7 Publicado: 9/10/2026 1:06:49
Hi Valery. This is a way. You can plot the time in T versus U, K or U+K. The plot in the figure shows that the energy is constant. In this case also, the total energy is the hamiltonian.
double_pendulum_RKA.sm (49,21 KiB) descargado 162 vez(es).
Editado 9/10/2026 1:19:29
ioan92 10/10/2026 18:59:13
#8 Publicado: 9/10/2026 20:11:32
ioan92
ioan92
181 me gusta en 125 mensajes.
Butterfly_Effect_Example.pptx (999,46 KiB) descargado 99 vez(es).
Hi Alvaro & Valery,
I enjoyed the matematical results of yours developements, without following all details.
I propose you a problem, dealing with the Butterfly Effect on a double pendulum - after some cycles, the 2 pendulums becoms distinct. Attached there is a simple gif file
#9 Publicado: 10/10/2026 0:03:48
Hi Ioan. Something like this.
double_pendulum_RKA Butterfly Effect.sm (50,58 KiB) descargado 161 vez(es).
A 5 usuarios les gustó este mensaje
Victor 16/10/2026 7:34:28, Valery Ochkov 10/10/2026 5:45:18, sergio 10/10/2026 8:51:15, ioan92 10/10/2026 12:34:44, Вячеслав Мезенцев 10/10/2026 16:02:19
#10 Publicado: 10/10/2026 12:30:41
ioan92
ioan92
Ooo it's wonderful!!!
My dumb explanation is that time delay generate between the 2 instances generate different precision in the solution graphics and hence the graphical difference (?).
Alvaro - All my thanks for your proverbial attention,
Have a nice WE,
Ioan
Alvaro 10/10/2026 19:03:11
