Gamma Functions
Gamma Functions - rapid speed with precision - Mensajes
#1 Publicado: 7/6/2021 17:07:11
Grupo: Moderator
Gamma function,
Lower Incomplete Gamma function,
Upper Incomplete Gamma function,
with almost instant speed and high precision.
gamma.sm (34,69 KiB) descargado 1431 vez(es). <---- least accurate
gamma_r2.sm (11,52 KiB) descargado 1422 vez(es).
gamma_r3.sm (11,8 KiB) descargado 1419 vez(es).
gamma_r4.sm (13,82 KiB) descargado 1419 vez(es).
gamma_r5.sm (11,38 KiB) descargado 1467 vez(es).
gamma_r6.sm (17,75 KiB) descargado 1383 vez(es).
gamma_r7.sm (28,8 KiB) descargado 1506 vez(es).
gamma_r8.sm (31,51 KiB) descargado 1530 vez(es).
gamma_r9.sm (36,93 KiB) descargado 1913 vez(es). <----imaginary numbers added
#2 Publicado: 8/6/2021 14:57:24
Grupo: Moderator
Thanks, will explore.
Main limitation is smath floating points.
Python gives much more accurate results with same algorithms.
Try the other one for gamma calculation.
#3 Publicado: 8/6/2021 19:21:30
round(■ ,■ ,■ ) ... undefined
H.T.Davis [Abramowitz & Stegun] -> very objective.
In the mean time I'm finishing two superb applications examples
... examples based on your first Gamma(a,x) version,
Thanks for that one, gorgeous ... Jean.
gamma_r2 [H.T.Davis].sm (57,43 KiB) descargado 1225 vez(es).
#4 Publicado: 8/6/2021 19:55:03
Grupo: Moderator
Undefined because you have an old version of smath.
Round(#,#,#) is not parsed through your program.
Use trunc() instead. And with more constants.
#5 Publicado: 8/6/2021 20:34:03
Grupo: Moderator
Technically this should be the most accurate one.
#6 Publicado: 8/6/2021 21:34:29
As offered ... two applications.
Now, the old Rooster is going in the bed marmite ... Jean.
gamma(a,x) Applications.sm (23,56 KiB) descargado 1342 vez(es).
#7 Publicado: 8/6/2021 22:08:00
Grupo: Moderator
I suggest you to change gamma function with gamma_r4.
It is 3 times faster and much more precise.
#8 Publicado: 9/6/2021 13:46:58
Thanks for gamma_r4
1. NO gain timing both applications
2. gamma_r4 Does NOT solve ... first version solves.
#9 Publicado: 9/6/2021 14:06:13
Grupo: Moderator
Thanks for gamma_r4
Speed may differ between linux and windows.
gamma_r4 is faster 3 times in linux.
What do you mean by 'does not solve'?
How should this page look like?
gamma(a,x) Applications.pdf (125,35 KiB) descargado 832 vez(es).
#10 Publicado: 9/6/2021 14:19:23
#11 Publicado: 9/6/2021 14:36:55
Grupo: Moderator
I think this is the same bug I mentioned earlier. Some functions don't like to be in another function.
Solution was to put a line but that method is not working in this case.
@Andrey or @Davide has to look at this.
#12 Publicado: 9/6/2021 16:03:46
Grupo: Moderator
Latest version is faster about 4 times.
#13 Publicado: 9/6/2021 16:23:05
Grupo: Moderator
It solves, not with conventional methods.
They tend to give errors, not gamma_r4's fault.
alglib is the answer, it usually gives result.
#14 Publicado: 9/6/2021 21:50:11
Good rescue ... OK.
As it looks, sr4 resides at the kernel level.
Thus, it plots but not solve(,,,,)
because not scalar wrt 'x' for the solve bloc.
#15 Publicado: 9/6/2021 22:06:36
Grupo: Moderator
Good rescue ... OK.
Nope, not related with kernel, blocks, scalability, etc.
It is probably a bug of solve(), roots(), FindRoot().
Gamma Function has nothing to do with it.
Even very simple ones suffer from this too.
Check below.
#16 Publicado: 9/6/2021 22:22:56
Grupo: Moderator
It seems solve(), roots(), FindRoot() doesn't like if statements.
I have updated the bugreport in Bugs and Problems > solve() bug.
Using cases() seems to solve the issue. Check the sample below.
#17 Publicado: 10/6/2021 11:16:16
Doctored version confirmed.
#18 Publicado: 10/6/2021 22:56:05
Grupo: Moderator
gamma_r5 has a serious flaw. It can't calculate a<0.5.
My bad, should check it carefully. Corrected page is below.
Refactored so it is faster, also get rid of recursive call.
I had to get around some smath bugs with line, if/cases, recursive.
Correlation of them gives weird errors.
Hope this version solves all issues and be the last one.
I know I have flooded this topic too much, sorry for inconvenience.
PS: gamma for negative non-integer values support corrected
#19 Publicado: 11/6/2021 10:16:24
You may not like my verdicts:
1. on-line faster has no or little interest, neither up ^307.
2. Your first version runs fine the two applications.
3. The champion is the long time ago published Alvaro Γ(x)
4. for these two applications [2] & [3] are same
but => [3] drops timing [2] from 24 s down 18 s
The drop in timing results from Alvaro Γ(x)
running at the kernel scalar level.
BTW, my original H.T. Davis sanity Mathcad & Alvaro Γ(x)
By same token, thanks Alvaro for your Γ(x).
Maths Special Gamma(a,x) Incomplete APPLICATIONS [Alvaro G(x)].sm (26,94 KiB) descargado 1229 vez(es).
#20 Publicado: 11/6/2021 12:45:20
Grupo: Moderator
1. 10^308 feature added for fully use IEEE capability.
2. gamma_r6 runs every possible applications.
3. don't want to disrespect, Alvaro's is a single line awesome code.
4. mine has same algorithm with more features, with faster calculation.
4. gamma_r6 is faster from gamma_r2 and gamma_r3 while trying to have all feature.
gamma_r6_app.sm (33,87 KiB) descargado 1413 vez(es).
Here is a side by side comparison with Alvaro's algorithm with mine.
On linux, gamma_r6 is faster about 20 percent.
Mostrar spoiler
