Data Exchange plugin
Data Exchange plugin - share data between SMath Studio and CSV/ODF/ODS/ODT/XeLaTeX files - Mensajes
#101 Publicado: 2/5/2013 17:31:53
kilele
kilele
134 me gusta en 397 mensajes.
I've just tried Martin's distro with the full plugin and got the same error as you, everything is broken (all samples in docs' plugin) with the same ionic.zip error.
Curiously enough, I think that this didn't happened in Linux (it worked only export correctly) but I want to do more tests in Linux.
edit:
yes i had a plugin disabled when starting smath but dont know which one yet. i'll edit this post later on.
#102 Publicado: 2/5/2013 17:42:13
Grupo: Moderator
Hi Radovan
The Full Package issue is caused by the ClosedXML library when SMath loads the plugins in the "Plugin" folder (if you put only the ClosedXML.dll file inside the plugin folder of a clean installation the message will appear), the OpenDocument issue by the Ionic.Zip library calling the related functions, I don't know if the 2 bugs are the same or simply similar...
It seems that Martin did not have this problem o_o
I don't know...
An early Post probably related: Issue SMATH Error - Won't Load Existing XMCD File (Build 0.96.4868) - XMCD File created by previous version will not open in new version
#103 Publicado: 2/5/2013 17:59:06
Grupo: Moderator
edit:
I tried it as well in Xubuntu using Martins' version. No errors about Ionic.zip. Save as ODT is working, but it seems that only the text can be saved. I did not manage to save formulas and plots.
#104 Publicado: 2/5/2013 18:11:51
Grupo: Moderator
I had a closer look at the DataExchange plugin under 0.96. For now, I see the XeTeX and csv export working fine, others still have to be checked, but there are problems in the example files. Unfortunately, I am not keeping pace with the flood of updates in the forum, thus it will take a while until distro and handbook will have settled and updated. Currently, I am just focussing on bug reports and test feedback.
#105 Publicado: 2/5/2013 18:24:56
Grupo: Moderator
Hello Davide,
I do not know why some of your post have to be approved sometimes
Hi Radovan
I don't know...
Sorry, I forgot that ClosedXML thing . Martin mentioned it few times.
#106 Publicado: 3/5/2013 3:28:59
kilele
kilele
Please download this file to see my test on SolusOS Linux,
Repository: Debian Stable; Desktop manager: Gnome2.3, btw SMath is very responsive in this manager.
This file contains the plugin docs and some screenshots showing errors while running the program.
An this is the plugin tested in Zorin(ubuntu)
http://www.mediafire.com/?p4ehqsr6pgs2vwl
Davide Carpi 3/5/2013 4:52:00
#107 Publicado: 3/5/2013 14:43:29
Grupo: Moderator
Hi Radovan
I don't know...
Just to try to conclude something about this. It seems to me that the same (or similar) problem comes with v0.96 and this plugin and the mcadEFI plugin by uni . As I understood this well, there will be fixed on the next SMath release. Until then these plugins are "off" the use, or to continue using them in 0.95. I hope I was right about it.
By the way, the activity on the Forum increased quite a lot, almost hard to follow . I am not complaining, just contrary
Davide Carpi 3/5/2013 14:50:00
#108 Publicado: 3/5/2013 14:54:15
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
If you really need mcadefi plugin you can do this (Andrey asked not tell about it nobody ):
Mostrar spoiler
Davide Carpi 6/5/2013 3:36:00
#109 Publicado: 3/5/2013 15:25:34
Grupo: Moderator
#110 Publicado: 3/5/2013 17:56:30
Grupo: Moderator
Thank you uni, this workaround solve all the issues
BTW this make dirty the SMath's installation folder, so it's really better to not use it if not strictly required.
best regards,
w3b5urf3r
#111 Publicado: 3/5/2013 18:15:42
Grupo: Moderator
It does not work for me, or I did not figure out . Never mind, I hope that will work for most of the users
#112 Publicado: 7/5/2013 19:29:57
Grupo: Moderator
PLUGIN UPDATED
- change of requirements: SMath Studio 0.96.4875 (07 May 2012)
- relative path improvements;
- ODS export vs symbolic optimization fix;
- patch on ODT embedded images for Linux users;
- SMath Viewer compatible.
best regards,
w3b5urf3r
ioan92 8/5/2013 3:45:00
#113 Publicado: 8/5/2013 1:12:28
Steve Swinbanks
Steve Swinbanks
2 me gusta en 11 mensajes.
Thanks. Seems to work fine now.
Steve
#114 Publicado: 8/5/2013 5:41:30
Grupo: Moderator
Steve
You're welcome :d
#115 Publicado: 10/6/2013 3:41:09
Grupo: Moderator
PLUGIN UPDATED
- XLSX features moved away (see Xlsx Import/Export plugin )
- plugin added to the Gallery (Latest Nigthly build)
- Added Guid (after installing the plugin, a message should appear opening old files, just skip it and save again the file)
best regards,
Davide
A 4 usuarios les gustó este mensaje
ioan92 10/6/2013 4:11:00, Вячеслав Мезенцев 10/6/2013 6:40:00, IVR 10/6/2013 15:34:00, Radovan Omorjan 10/6/2013 3:56:00
#116 Publicado: 17/9/2013 13:10:04
Grupo: Moderator
UPDATED (Gallery only)
- fixed: SMath Studio 0.96.4909 (10 June 2013) vs XeLaTeX saves
#117 Publicado: 30/12/2013 7:53:11
paolo1963
paolo1963
1 me gusta en 4 mensajes.
when the program starts, the following message appears
operating system Win 7
smath versione 096 4868
net framework 4.5.1
#118 Publicado: 30/12/2013 9:47:42
Grupo: Moderator
Hi Paolo,
I can't reproduce your issue (win7 x64 - SMath 0.96.4909)
Are you sure that this plugin cause the issue? copy and paste the red string ( %APPDATA%\smath\extensions\plugins ) in your windows start menu, press the return key and then delete the plugin folder (5dce7298-9e5f-4120-9a2e-49b16daa02a3) then try to start SMath again.
Davide
#119 Publicado: 30/12/2013 15:11:25
paolo1963
paolo1963
I uninstalled the version of SMath 096 4868 and I installed version 096 4909 now the program starts.
Save in *. odt work,
while saving in *. tex from the following error message:
#120 Publicado: 3/1/2014 20:56:45
Grupo: Moderator
Really strange, I can't reproduce this issue
The problem is related to some worksheet (empty file, with figures, with text, with math), some machine, or is general?
Have you the same issues with the unofficial portable version?
You could try to share here your system informations (Development Tools plugin > System informations > save as... > attach here the file)
