remove all declared variables
remove all declared variables - is there any function to remove all declared variables? similar to clear - Mensajes
#1 Publicado: 29/9/2021 23:59:19
JOSEPH7
JOSEPH7
0 me gusta en 1 mensajes.
Help!
#2 Publicado: 1/10/2021 18:45:30
Oscar Campo
Oscar Campo
135 me gusta en 309 mensajes.
Grupo: Moderator
Help!
You can install the "Special Functions" plugin, which has a Clear() function as you need.
Andrey Ivashov 1/10/2021 18:49:00
#3 Publicado: 1/10/2021 18:51:47
Grupo: Super Administrator
Actually this plug-in is built-in into the installer package.
Oscar Campo 2/10/2021 2:58:00
#4 Publicado: 2/10/2021 11:36:43
Grupo: Moderator
If SMath would allow to clear variables inside a matrix,
that would be an answer for your request.
But it does not, so this is a dead-end.
For now, you have to make all your variables an element of vector/matrix,
if you want to clear all of them in single command.
Or manually clear them one by one.
#5 Publicado: 16/10/2021 15:08:40
Help!
Hi. I think what the user request is a function similar to "clear all" in Matlab.
Given that include is capable of collecting all the names of the variables of a worksheet as the "whos" command of Matlab would do, perhaps the include code can be used to implement the option to delete all the variables with Clear( "all" ) or something similar.
#6 Publicado: 17/10/2021 7:41:24
is there any function to remove all declared variables? similar to Clear
Clear(■,■,■,■,■) ...
clears the system in cause [variables, vectors, matrices]
Clear(x,y,z,m,ω)=1 are evaporated from the system.
Page17 Clear.sm (15,52 KiB) descargado 1597 vez(es).
#7 Publicado: 17/10/2021 12:27:54
remove ... you mean clear for reuse ?
Option Find [Ctrl+F] finds numerical single value,
it takes only one search at time, greek not from
palette but copied from palette
Does not distinguish math regions from text.
Not much use for Find.
If the letter is a vector just ignored.
#8 Publicado: 17/10/2021 14:29:26
Grupo: Moderator
Yes Razonar, probably that is the OP's request.
He doesn't want to write every variable into Clear().
Just Clear(ALL) and puff, all defined shall be cleared.
#9 Publicado: 27/5/2023 16:25:38
OlliL
OlliL
0 me gusta en 3 mensajes.
Hi, sorry to resurrect the thread, just chiming in to say that I would really love a Clear(ALL) function too.
Often it would be nice to use a one SMath file to make multiple repeat calculations but not being able to clear the variables makes repeat calculations extremely risky.
#10 Publicado: 27/5/2023 21:17:00
The Clear(All) will not clear matrix/vector that are not resident (isolated).
Fromm observation, in that case, set XY the matrix XY:=0
That clears the global system calculation.
#11 Publicado: 28/5/2023 9:12:56
Not all variables/parameters are declared.
Many reside @ the kernel level, not recognized by Clear(,,,)=
I have an instance that can't be renewed by Clear(,,,)=
#12 Publicado: 6/6/2023 2:06:54
OlliL
OlliL
Good morning!
So there is a Clear(All) function? How is it used?
#13 Publicado: 6/6/2023 11:27:27
So there is a Clear(All) function ?
How is it used ?
AFAIK, there is no Clear(All) ... what is All ?
Clear(,,,) also restores the built-in.
Maths Clear Restore.sm (9,14 KiB) descargado 1399 vez(es).
#14 Publicado: 6/10/2023 3:50:47
rkronhofer
rkronhofer
Hy,
is there any update on such a "Clear(All)" function?
Would be really helpful to have it like this
a:=5
b:=6
Clear(All):=1
a=?
b=?
Thanks for answers
BG
#15 Publicado: 6/10/2023 13:31:53
Build your system algo style complete wrt parameters
Collapse in utilities, top document.
Now, you are in-situ command line mode ...
Nothing to clear. Just plug parameters in each command line.
#16 Publicado: 8/10/2023 13:55:30
Grupo: Moderator
There is not a Clear(All) function.
No method is applicable to remove all variables at once.
There is not an update, yet.
Unfortunately, I guess none shall appear on horizon soon.
#17 Publicado: 9/10/2023 6:45:04
Grupo: Moderator
CustomFunctions plugin
direct link: link removed (now the extensions manager works again)
Oscar Campo 9/10/2023 7:38:00, Arie 9/10/2023 10:58:00, overlord 9/10/2023 18:20:00
#18 Publicado: 9/10/2023 18:23:22
Grupo: Moderator
This works!!!
Thanks for the beta update.
What would you think about revising output string?
Instead of "1", it can be;
arg==1 --> "All cleared"
arg==2 --> "Variables cleared"
arg==3 --> "Functions cleared"
Oscar Campo 9/10/2023 20:25:00
#19 Publicado: 10/10/2023 11:54:52
Grupo: Moderator
This works!!!
You're welcome, glad it seems to work correctly on first try. I still have to check carefully the (2)nd option, since as it is now it deletes "anything that is not a function" (including some low-level stuff).
Usually I prefer a binary output, since can be used inside if/else functions independently from localizations, future enhancements of descriptions, and string comparision issues.
I'll think about it.
#20 Publicado: 11/10/2023 15:49:18
If you have discretized [x,y,z ...] in part 1 of project
as that part 1 is complete ... Clear(x,y,z) for next part of the project.
Assume part 1 & part 2 are constructed around 5 parameters.
If you ClearAll(,,,,,) past part 1
You have to re-install those 5 parameters that over-ride
themselves from the new ones.
