1 páginas (8 elementos)
Differentiation operator does not evaluate symbolically - Translate a differential operator from SMath to Maxima - Mensajes
Do you know why or what could be the problem for SMath not translating properly a dy/dx. I need to write these operators in Maxima to solve a differential equation...
Thanks in advance,
Differentiation.sm (9,34 KiB) descargado 1149 vez(es).
Thanks in advance,
I have found a workaround, with eval_string() from Maxima.
Differentiation.sm (13,39 KiB) descargado 1158 vez(es).
WroteHello,
Hola tocayo. Is this the problem?: always it is diff(y,x)=0, but diff(y(x),x) remains unevaluated and is the correct form to express the derivative of a function.
frapuano 31/5/2020 4:51:00
You are mixing two CAS that will not pass QA [Quality Assurance].
My understanding is that what was usable from Maxima is native in Smath.
Smath native derivative operator works from book library.
sin(x), ln(x), exp(x) ... OK
Gamma(x), erf(x) ... zap. We have them otherwise.
Differentiation.sm (17,82 KiB) descargado 1164 vez(es).
Thank you Jean, I am trying to test some symbolic solutions of differential equations just for a course video where I show some of the capabilities that are not present in Mathcad (Prime).
WroteThank you Jean, I am trying to test some symbolic solutions of differential equations just for a course video where I show some of the capabilities that are not present in Mathcad (Prime).
Very few DE have symbolic solutions, unless from Handbooks.
Few of them are available in Smath ... will be back on that.
WroteI am trying to test some symbolic solutions of differential equations just for a course video where I show some of the capabilities that are not present in Mathcad (Prime).
If Mathcad Prime does not solve those attached ... Oh !
ODE Symbolic 4_Flies.sm (130,62 KiB) descargado 1183 vez(es).
ODE Symbolic Bernoulli.sm (11,38 KiB) descargado 1199 vez(es).
ODE_Laplace 1rst [Type 2].sm (22,68 KiB) descargado 961 vez(es).
ODE Symbolic Verhulst [Logistic].sm (25,55 KiB) descargado 1025 vez(es).
ODE Symbolic Lambert.sm (21,81 KiB) descargado 1195 vez(es).
ODE_Laplace 1rst [Type 1].sm (24,7 KiB) descargado 976 vez(es).
ODE_Laplace 2nd [Type 3].sm (34,62 KiB) descargado 1037 vez(es).
ODE Symbolic Eiffel.sm (21,45 KiB) descargado 1156 vez(es).
