1 páginas (6 elementos)
Units and Control Boxes - How to set units for output variables of control boxes? - Mensajes
Hello!
If I have a slider or checkbox, is there a way to define the units for my output variable directly on the settings?
I can handle units outside those just fine, but I'd really like to get my variables with their units right from the boxes.
Sorry if it's a stupid question.
Thanks in advance!
Thanks in advance!
hello [userlink]JoãoBR[/userlink],
is not possible, neither for visualization inside the control itself.
One day, maybe (need to figure out something to be applied in generic cases, mixed units in the input matrix)
Thank you, Davide. It's really a pitty.
Let me ask you this, then:
I want a variable like "fck" in MPa, and build a slider to set something like "Set_fck", how could I make "fck" get "Set_fck" numerical value but keeping it in MPa?
Yes, alyles, that's it, but I can't do it for some reason.
I've tried typing the apostrophe and using the CRTL+W shortcut, but the unit selection option just doesn't appear.
These methods work just fine when I create a new variable.
Done it! CTRL+W and using the apostrophe did not work, but *MPa+TAB did the job.
Thank you all
Thank you all
