Units and Control Boxes
Units and Control Boxes - How to set units for output variables of control boxes? - Сообщения
#1 Опубликовано: 12.02.2018 13:55:07
João Felipe Seráfico Melo
7 сообщений из 62 понравились пользователям.
Hello!
If I have a slider or checkbox, is there a way to define the units for my output variable directly on the settings?
I can handle units outside those just fine, but I'd really like to get my variables with their units right from the boxes.
Sorry if it's a stupid question.
Thanks in advance!
#2 Опубликовано: 12.02.2018 15:02:36
hello [userlink]JoãoBR[/userlink],
is not possible, neither for visualization inside the control itself.
One day, maybe (need to figure out something to be applied in generic cases, mixed units in the input matrix)
#3 Опубликовано: 12.02.2018 16:21:41
Thank you, Davide. It's really a pitty.
Let me ask you this, then:
I want a variable like "fck" in MPa, and build a slider to set something like "Set_fck", how could I make "fck" get "Set_fck" numerical value but keeping it in MPa?
#4 Опубликовано: 12.02.2018 16:48:19
Arie
Arie
Is this what you're asking for?
fck.sm (2,58 КиБ) скачан 1287 раз(а).
Andrey Ivashov 12.02.2018 23:32:00, Davide Carpi 13.02.2018 04:41:00
#5 Опубликовано: 12.02.2018 19:48:20
Yes, alyles, that's it, but I can't do it for some reason.
I've tried typing the apostrophe and using the CRTL+W shortcut, but the unit selection option just doesn't appear.
These methods work just fine when I create a new variable.
#6 Опубликовано: 12.02.2018 22:52:06
Done it! CTRL+W and using the apostrophe did not work, but *MPa+TAB did the job.
Thank you all
