1 páginas (6 elementos)
Standard templates? - Is it possible to create (and re-use) a template in smath? - Mensajes
Hi everyone, I’ve been using smath for about a year now (since mathcad became completely rubbish!) and use it for standard engineering calcs (mechanical and structural mainly).
I’m freelance so tend to perform calcs for many clients and have not yet found a way to create a standard calculation sheet template.
For example, whenever I start a new project I’d like a header or something on the front page to display my company name and a few other fields for title, project number, that sort of thing. Possibly even have a margin down one side for referencing standards or notes. Something like the sci calc sheets that are online would be great!
Does anyone know of a way to do this or is there a plug-in somewhere?
Any advice would be much appreciated.
Thanks!
Richard
Thanks!
Richard
you can use:
Insert -> Header and Footer
Insert -> Field
Also you can see this post by Alvaro (Razonar)
https://en.smath.com/forum/yaf_postst13853_Automatic-numbering-sections-book.aspx
Insert -> Field
Few ways of presenting professional works. Any use ?
Template.sm (15,57 KiB) descargado 1905 vez(es).
Template Background Multiple.sm (14,22 KiB) descargado 1817 vez(es).
Template Cartouche.sm (19,42 KiB) descargado 1732 vez(es).
Template Background Construct.sm (47,88 KiB) descargado 1809 vez(es).
Template Cartouche Venturi.sm (21,78 KiB) descargado 1685 vez(es).
Template Else Source.sm (3,94 KiB) descargado 1730 vez(es).
Template Cartouche CREATE.sm (53,17 KiB) descargado 1654 vez(es).
Template Cartouche Saved.sm (4,53 KiB) descargado 1626 vez(es).
Template Guy.sm (2,65 KiB) descargado 1733 vez(es).
Template Cartouche Example.sm (34,49 KiB) descargado 1652 vez(es).
Template YellowCorn.sm (3,31 KiB) descargado 1684 vez(es).
Template Cartouche Geoff.sm (31,7 KiB) descargado 1647 vez(es).
Template Cartouche Otherwise.sm (74,54 KiB) descargado 1663 vez(es).
Hi, apologies for the delayed response! The templates linked below are great - thank you for providing these.
I've looked at a few and haven't quite found what I need yet but I'll work on it. Once I have something I'll post it here so everyone else can use it (if they want to!)
Thanks again,
Richard
Thanks again,
Richard
WroteI've looked at a few and haven't quite found what I need yet
Visit them all for the next month !
Foot note standard/references best go in collapsed above document.
Create an empty file with your template settings and set it as readonly, when you try to save Smath will ask you a new name.
