bug with function with programming - calling function with a for loop loops forever - Mensajes
Please see attached .sm file.
The comments describe the bug ...
Thanks in advance
test bug.sm (16,34 KiB) descargado 1520 vez(es).
WroteFirstly thank you for such a wonderful free alternative to MathCad 15.
Thanks in advance
Did not reproduce it...
I could not reproduce either..
Yes, did not reproduce.
WroteHmm,
I just re-tested on my home PC, freshly booted, same problem.
appVersion(3) = "0.99.7030" not .7219 <- Could this be the difference?
I can confirm this hangs on 7030. I was running 7219 before and did not have an issue. My guess is this should be fixed in next stable release and already seems to be fixed in Beta releases. The question is whether or not the "fix" is intentional or not.
I will install 7219.
Hopefully my Maxima plugin continues to work.
WroteWroteI will install 7219.
IMHO, not the best option yet.
Who can guess what the angle for loop should be doing ?
There are no maths associated with !
angle was originally used as such, but I modified it as a troubleshooting step, with no change to the bug's behavior
loss := loss + I2ttot(sin(angle*deg)*Ipk)
WroteOK thanks.
It works properly on .7219.
But Maxima doesn't work.
What error do you get? Maxima works fine on my end. May need to update the plugin.
EDIT: I was able to get Maxima running with .7219.
WroteI just re-tested on my home PC, freshly booted, same problem.
No matter SS version, by far not a Mathcad clone.
Show some Mathcad snippets ... would help doctor the patient.
What from Maxima ? Plot, Solve ...
Wrote^ Doesn't installing Maxima require running Update16.sm which will then upgrade it to .7030?
Not sure? Maybe Martin can answer. I already had maxima setup on a previous version. I simply updated to 7219 and Maxima came along for the ride.
WroteWrote^ Doesn't installing Maxima require running Update16.sm which will then upgrade it to .7030?
I was able to install Maxima with .7219, thank you.
