1 páginas (5 elementos)
solve() by Maple Plugin gives an "arctan() function not defined" error - solve() by Maple Plugin gives an "arctan() function not defined" error - Mensajes
I found this behavior working with Maple plugin:
I think that it would be easily fixed by uni
Thanks in advance!
Oscar
Thanks in advance!
Oscar
@uni
I think that you can use directly:
using the Functions.* you don't need to write the right SMath function name.
best regards,
w3b5urf3r
ExpressionString = ( new Regex( @"\batan\(" ) ).Replace( ExpressionString, Functions.Arctg + @"(" );
ExpressionString = ( new Regex( @"\barctg\(" ) ).Replace( ExpressionString, Functions.Arctg + @"(" );
best regards,
w3b5urf3r
Вячеслав Мезенцев 29/5/2013 21:09:00
Oscar, could you attach the file and the log (mvr5.txt)? As for me your example works fine.
@w3b5urf3r
Thanks, I forgot about that.
@w3b5urf3r
WroteOscar, could you attach the file and the log (mvr5.txt)? As for me your example works fine.
Here the files.
Thanks in advance!
Oscar
Вячеслав Мезенцев 30/5/2013 23:01:00
WroteWroteOscar, could you attach the file and the log (mvr5.txt)? As for me your example works fine.
Here the files.
Thanks in advance!
Oscar
Fixed and updated. Try now.
