Division with vector
Division with vector - Mensajes
#1 Publicado: 15/3/2018 0:42:55
vijaykhatri
vijaykhatri
1 me gusta en 23 mensajes.
I am trying to to the following:
n:=[1..1200]
s(n):=(1200-n)/1200
I(n):200/(1+2/s(n))
"I get an error divisor matrix must be square"
any suggestions???
Vijay
#2 Publicado: 15/3/2018 2:16:37
I am trying to do the following:
For God sake: what are you trying to do ?
#3 Publicado: 15/3/2018 11:15:54
vijaykhatri
vijaykhatri
Thank you for the response, I am new to this forum, is there a way I can send a .pdf file of the work I had done in MathCad, this will help you see what I am trying to do in Smath.
Vijay
#4 Publicado: 15/3/2018 12:10:39
Vijay
Try this much easier:
1. compact as much as you can your part of Mathcad
2. PrintScreen, paste in Paint, clean
3. In your C:\ ... create a directory "Snippets"
4. Try to save your Paint as *.PNG in your "Snippets"
5. then => add file from the Smath forum
by double click on the *.PNG in the Snippets directory.
#5 Publicado: 15/3/2018 13:29:30
Grupo: Moderator
you divide by a vector. If you want to apply that by element, then use the vectorize operator.
Alternatively, you can use implicit loops.
In any case make sure that you don't divide by zero.
To upload images or files, use the paperclip button ("Insert an existing...." )
matrix2.sm (19,87 KiB) descargado 1151 vez(es).
#6 Publicado: 15/3/2018 14:29:42
Maths Matrix Vijay.sm (11,41 KiB) descargado 1140 vez(es).
#7 Publicado: 15/3/2018 15:43:29
vijaykhatri
vijaykhatri
Vijay
#8 Publicado: 15/3/2018 18:34:53
Too many parameters are missing to reproduce
r1, r2, E, x [u in Smath ... back to x in plot]
#9 Publicado: 15/3/2018 23:21:52
vijaykhatri
vijaykhatri
Thank you for your efforts, that's what I am looking for. I am resending the data with all the information. I have a few questions on your previous post, there is an arrow above 2/s and I(u)^2.What is that function. Also, you have used the value of u = 13.5? Also, when you plot the graph, did you just type T(13.5) to get the graph?
#10 Publicado: 16/3/2018 0:18:34
I am re-sending the data with all the information.
1. The arrow is the vectorising operator [same as Mathcad].
2. 'u' is the wild parameter of same nature as r1,r2
3. The system runs over 'n' taken into account wrt the vectorised arguments.
4. Shift@ to get the plot region, type T(13.5) then [ to get the index operator
then type x. The Smath plot argument is 'x'. So, by indexing, it will plot over
the running 'x'. If you want to plot ln(x), just type ln(x) in the plot place holder.
I will try to code your latest information, but busy next three days.
#11 Publicado: 16/3/2018 0:55:26
Now, you have another story [a different project].
Vijay(1).sm (26,88 KiB) descargado 1171 vez(es).
#12 Publicado: 16/3/2018 7:46:41
Grupo: Moderator
starting from the basics, hope it might help you
example.sm (17,79 KiB) descargado 1327 vez(es).
frapuano 16/3/2018 16:00:00
#13 Publicado: 16/3/2018 9:45:00
vijaykhatri
vijaykhatri
Thank you so much, this really helps. May I suggest you post this as an example so everyone can benefit.
Vijay Khatri
#14 Publicado: 16/3/2018 9:46:34
vijaykhatri
vijaykhatri
Thank you, you have given me ideas that I can try to implement.
#15 Publicado: 16/3/2018 10:18:52
Back to original.
Vijay(1).sm (7,11 KiB) descargado 1183 vez(es).
#16 Publicado: 16/3/2018 12:49:43
You can mine Smath by visiting "Samples".
Without the circuit, it looks dead.
#17 Publicado: 16/3/2018 13:46:53
vijaykhatri
vijaykhatri
Attached is another similar file for which I have included the circuit diagram. I am assuming this will be posted in samples in this foroum.Archivo no encontrado.Archivo no encontrado.
#18 Publicado: 16/3/2018 19:47:03
CBG
CBG
78 me gusta en 312 mensajes.
Something like this?
Vijay_CBG_Jean.sm (13,52 KiB) descargado 1168 vez(es).
Carlos
#19 Publicado: 16/3/2018 20:55:29
Visit => Samples => Motor Analysis [20180316, 19:52]
Drawing was sharpened to the possible limit,
if you have a better one, please offer.
#20 Publicado: 16/3/2018 21:05:16
vijaykhatri
vijaykhatri
Carlos
Thank you Carlos, just one question, how did you create the vertical line with multiple entries.
