solving simultaneous equations with Solve
solving simultaneous equations with Solve - Solve() Maxima not working - Mensajes
#1 Publicado: 5/4/2022 15:45:27
Mo
Mo
0 me gusta en 34 mensajes.
hi,
I used the Solve function a lot before but for some reason it does not work for this simple example.
I need to get the RayLeigh Damping factors alpha and beta using two frequencies, so two simple simultaneous equations should do it. tried using Solve but no luck.
Does anyone know why it is not solving?
Thanks in advance
Archivo no encontrado.Archivo no encontrado.
#2 Publicado: 5/4/2022 16:39:40
127 me gusta en 342 mensajes.
Mostrar spoiler
test_sergio.sm (8,05 KiB) descargado 1246 vez(es).
Mo 5/4/2022 22:22:00
#3 Publicado: 5/4/2022 18:24:50
Grupo: Moderator
You can use roots() for your function. And a vectorize() can simplify it.
However, to use Assign() you will need this function to merge vars and solutions.
Assign_without_Maxima Solve().sm (7,36 KiB) descargado 1317 vez(es).
#4 Publicado: 5/4/2022 22:22:48
Mo
Mo
Thanks Overlord, PompelmoTell, greatly appreciated!!
#5 Publicado: 6/4/2022 10:28:07
⚜ Kenny Lemens, P.E. ᵂᴵ
85 me gusta en 181 mensajes.
Greetings,
Another approach would be to use some elbow grease, you can substitute terms by hand and solve for 𝛼 and 𝛽:
Keypress (You can copy/paste the following into your worksheet):
α:{2*D*ω.1*ω.2}/{ω.1+ω.2}
β:α/{ω.1*ω.2}
*NOTE: ω.1 and ω.2 shown above are variables with subscript, they are not vectors ω[1 and ω[2; You should be able to substitute ω.1 for ω[1 if that serves your purposes.
- Kenny Lemens, P.E.
Mo 6/4/2022 11:57:00
#6 Publicado: 6/4/2022 11:40:36
Fridel Selitsky
Fridel Selitsky
520 me gusta en 451 mensajes.
If the damping coefficients are denoted by α1 and α2, you can use the function al_nlegsoive
test.sm (6,99 KiB) descargado 1332 vez(es).
sergio 6/4/2022 12:26:00, Mo 6/4/2022 11:57:00
#7 Publicado: 7/4/2022 11:08:53
Fridel Selitsky 7/4/2022 11:54:00
#8 Publicado: 7/4/2022 13:43:03
... more in there from native Smath code.
Solve FindRoot FORUM.sm (10,9 KiB) descargado 1298 vez(es).
#9 Publicado: 7/4/2022 17:27:55
Grupo: Moderator
solving with uni's latest addition mathcad blocks;
you wouldn't need Eq: actually, but it can be shown.
mathblock.sm (5,15 KiB) descargado 1300 vez(es).
Mo 9/4/2022 22:28:00
#10 Publicado: 7/4/2022 18:19:34
Grupo: Moderator
I think this is the most sophisticated method of my way.
It can get unknowns from equation, solve them.
In the end assigns numerical values to unknowns.
You don't need to define alpha or beta or any variable.
All process is automatic.
mathblock_v2.sm (5,19 KiB) descargado 1319 vez(es).
There is also this way for guess define.
#11 Publicado: 8/4/2022 2:19:42
Fridel Selitsky
Fridel Selitsky
This is good, but for a system of linear equations(our case), the guess can be arbitrary.
#12 Publicado: 8/4/2022 20:04:07
Grupo: Moderator
And finally a version with Solve() and list injection region:
mathblock_Solve.sm (4,86 KiB) descargado 1277 vez(es).
sergio 9/4/2022 4:48:00
#13 Publicado: 11/4/2022 9:57:44
Greetings,
If plugins are considered, you can also consider the use of Maple:
In the image I posted, the 'equal sign' shown on those two equations are actually symbolic equals; keypress: [ctrl] + [.] instead of keypress [=].
Kenny Lemens, P.E.
#14 Publicado: 11/4/2022 16:44:08
Hi. The isol solution, using only the Mathcad block plugin.
isol_example.sm (68,13 KiB) descargado 1258 vez(es).
isol_example.pdf (34,57 KiB) descargado 729 vez(es).
sergio 12/4/2022 5:01:00
#15 Publicado: 14/4/2022 12:10:17
Mo
Mo
Thank you all for the feedback, is there a literature or manual to explain the Mathcad block plugin?
Thanks
#16 Publicado: 14/4/2022 14:54:00
Thank you all for the feedback, is there a literature or manual to explain the Mathcad block plugin ?
For that particular example, maple is an algebraic export.
Mathcad block has not yet been exemplified in Smath Community
of what it can do vs what native Smath can't.
Codes Solve.sm (12,46 KiB) descargado 1301 vez(es).
#17 Publicado: 14/4/2022 19:43:45
Exercise the Mathcad bloc
#18 Publicado: 14/4/2022 20:19:07
Grupo: Moderator
Thanks
We have what Viacheslav provided us.
There are some samples or functions too which individual users uploaded.
You can look the extension page for some examples.
And there are some samples in forum topic that users posted.
It may be a small bunch, but we try to understand its capabilities.
This feature/plugin is also new to us.
https://en.smath.com/forum/yaf_postst726_Mathcad-Toolbox.aspx
