Cannot run in Ubuntu 22.04
Cannot run in Ubuntu 22.04 - Mensajes
#1 Publicado: 28/9/2023 15:57:49
vroberts
vroberts
0 me gusta en 7 mensajes.
I cannot run the SmathStudio appimage in Ubuntu 22.04. Other appimage programs do run on the system, so I seem to have the proper resources. There is no error message. Just nothing.
#2 Publicado: 28/9/2023 18:51:04
Grupo: Moderator
This is mono bug of debian based distros. You can find detailed explanation about it at link below.
https://en.smath.com/forum/yaf_postsm75553_SMath-in-Linux.aspx#post75553
#3 Publicado: 29/9/2023 12:57:15
vroberts
vroberts
If SM does not run on Debian based distros, I wonder why Ubuntu is listed on the Download page as the example of a Linux distro.
#4 Publicado: 20/7/2024 5:05:00
David Cigna
David Cigna
0 me gusta en 2 mensajes.
I know this is a 10 month old thread, but this is such a common problem that I think it's worth responding.
overlord did not say that smath does not run on Debian based distros. I think that what he implied is that if it won't run, then you need to fix your mono installation.
One thing that finally worked for me was to install not just the mono runtime, but also the developer package:
sudo apt update
sudo apt upgrade
sudo apt install mono-runtime mono-devel
You can refer to this thread for more ideas:
Ask Ubuntu
#5 Publicado: 20/7/2024 5:23:41
Grupo: Moderator
In fact, you even don't need to fix or install anything. This is a common mono bug and it can be fixed with editing your smathstudio mono execution file.
With respect to pdalet, here is his post.
Good New for ubuntu users
SMath Studio runs on ubuntu 22.04 without sudo.
Modify smathstudio_desktop_mono
#!/bin/sh
export MONO_WINFORMS_XIM_STYLE=disabled
exec mono "./SMathStudio_Desktop.exe" "$@"
Ph.DALET
Lyp Champollion
Figeac-FRANCE
#6 Publicado: 3/8/2024 0:25:22
giddyApples8
giddyApples8
0 me gusta en 15 mensajes.
#!/bin/sh
Ph.DALET
Lyp Champollion
Figeac-FRANCE
Can you please explain how (which app to use) to modify the mono file?
#7 Publicado: 3/8/2024 3:55:00
Grupo: Moderator
This file (smathstudio_desktop_mono) is just a shell script file.
Edit it with your favorite text editor.
vim, leafpad, kate, nano, scite, notepadqq, etc etc
#8 Publicado: 6/8/2024 1:59:10
David Cigna
David Cigna
Just to add a tiny bit for those that are not linux gurus. Overlord's suggestion works well if you place the shell script in the same folder as SMathStudio_Desktop.exe, cd into the folder with a command line, then execute smathstudio_dektop_mono. For those that prefer using a launcher to the keyboard, you need to modify the script a little more.
#!/bin/sh
cd /home//Applications/SMath_Studio
I made a folder called SMath_Studio within the Applications folder (which may or may not already exist in your home directory) and copied the entire SMath file structure there. Obviously, replace with your user name. Now create an entry in your launcher that executes the shell script. The reason that all of this is necessary is because SMathStudio_Desktop.exe needs to start in the same folder as all of the associated SMath files. Simply specifying the complete path in the "exec mono" line will not be enough.
#9 Publicado: 31/1/2026 0:04:04
⚜ Kenny Lemens, P.E. ᵂᴵ
85 me gusta en 181 mensajes.
//////////////// DISCLAIMER \\\\\\\\\\\\\\\
I am new to Linix (Ubuntu - Zorin OS)
Greetings,
I am currently binge watching a plethora of videos covering Ubuntu, LInux, Wine, Gear Lever: installs, debugging, and the such. Here is my current understanding:
  1. Mono is outdated, a project that has hence been folded into WineHQ
  2. The Mono distribution WILL work with Mono, or with WineHQ, either one having different degrees of success (e.g., Mono displayed math regions, but not some button text, while Wine showed button text, but not some math region text) ¯\_(ツ)_/¯
  3. The *.appimage file for Ubuntu doesn't seem to 'work', even after authorizing it to run, neither through 「fuse2」, nor 「Gear Lever」: No errors, no messages.
  4. I have developed some plugins, so I'm aware that SMath is an Windows Forms application/.net/Microsoft
Is it a valid understanding that SMath does not have a "Linux deployment," but rather it is a Windows Application that *can* run on Linux; more or less supported through the Mono project.
Therefore, here are my questions:
  • Is there an installation guide for Linux Deployments?
  • Does the Ubuntu deployment appImage file corrupt? if not, how is it supposed to be used?
  • If SMath only works if it is mounted to "Mono" or "WineHQ": is there a way to double click a *.sm file and have the SMath open? or must we enter that command through the terminal
I have a 'working' solution, but I'm looking for the cleanest/mainstream/recommended/seamless method as to how best install/utilize SMath Studio.
May this be of Good Help;
#10 Publicado: 2/2/2026 18:57:04
Grupo: Moderator
Usually Debian based distros have issues with Mono compiled programs.
Check if SMath runs with sudo from terminal. Sometimes a missing library indicated at terminal.
If you write version of your Zorin installation, I can check it from live iso.
#11 Publicado: 2/2/2026 22:05:07
Greetings,
Thank you for that reply. From experiments, SMath doesn't like WineHQ much on ZorinOS (Ubuntu-based); issues with displaying/interacting with Unicode characters. I was going to try Bottles and other alternatives (like VM) to see if there is a better environment for SMath. Looks like the same issue as noted on this other thread:
Hello, I use Smath studio for education purpose. I previously had it on debian strech were it works very well but now I switch to ubuntu 18.04 and I install it with the deb package.
The issue is I cannot see all the symbols in the toolbar. It's the symbol wich is Black over white in omorr screenshot.
Sombody have an idea? a dependencie missing?
ref: https://smath.com/en-US/forum/topic/4za86Z/SMath-Studio-for-Ubuntu#msg122545
(I'm working off of Zorin OS 18 Educational; v1.42.0)
Editado 2/2/2026 22:07:30
#12 Publicado: 3/2/2026 23:51:34
Grupo: Moderator
This "bug" exist on Debian and Ubuntu for a very long time.
And it has not been fixed at least 10-15 years I can say.
It is simply not SMath's fault, there are several bug reports on this issue.
Not specific to SMath either, very simple codes have this issue too.
I don't have this error on my Void Linux, nor on Arch Linux vm's btw.
You can see issue being discussed here. There are multiple topics about this actually.
https://github.com/mono/mono/issues/13049
Editado 5/2/2026 1:04:14
#13 Publicado: 7/2/2026 5:53:19
Grupo: Moderator
I could manage to make SMath work under Zorin OS.
This method should work with all Debian or Ubuntu based distros.
This proves problem is with mono installation, not SMath.
1 - I downloaded source code of latest mono from winehq, which is mono-6.14.1.tar.xz when this written.
https://dl.winehq.org/mono/sources/mono/mono-6.14.1.tar.xz
2 - I installed necessary packages to build mono from source, needed information gathered from site below.
https://www.mono-project.com/docs/compiling-mono/linux/
sudo apt-get install git autoconf libtool automake build-essential gettext cmake python3 curl
3 - I installed libgdiplus which is necessary to run SMath mono later.
sudo apt-get install libgdiplus
4 - I patched two files (mono-heapviz and w32file-unix.c) using a text editor.
--- a/mono/metadata/w32file-unix.c
+++ b/mono/metadata/w32file-unix.c
@@ -28,7 +28,6 @@
 #endif
 #ifdef __linux__
 #include <sys/ioctl.h>
-#include <linux/fs.h>
 #include <mono/utils/linux_magic.h>
 #endif
 #ifdef _AIX
--- a/scripts/mono-heapviz
+++ b/scripts/mono-heapviz
@@ -7,7 +7,7 @@
 from __future__ import print_function
 import sys, os
-import Image, ImageDraw
+from PIL import Image, ImageDraw
 from xml.sax import ContentHandler, make_parser
 from xml.sax.handler import feature_namespaces
 from optparse import OptionParser
5 - I compiled and installed mono with info from mono site.
PREFIX=/usr/local
VERSION=6.14.1
tar xvf mono-$VERSION.tar.xz
cd mono-$VERSION
lib32disabled=yes
./configure --disable-system-aot --prefix=$PREFIX
make
sudo make install
6 - I modified smathstudio_desktop_mono file so a cumbersome error is fixed.
#!/bin/sh
7 - I imported certificates to mono for web and server connection.
sudo cert-sync /etc/ssl/certs/ca-certificates.crt
This is the result when I run SMath with ./smathstudio_desktop_mono
Editado 8/2/2026 21:22:59
Rafael H Padilla Velázquez 7/2/2026 18:17:30, ⚜ Kenny Lemens, P.E. ᵂᴵ 10/2/2026 14:28:12
#14 Publicado: 9/2/2026 21:06:56
Grupo: Moderator
If you look for a shorter and easier way and if you would trust a third party appimage (well, it was packed by me), you can use this file.
https://smath.com/en-US/forum/topic/bgXHk4-last/AppImage-File-Crashes-on-Linux-Mint-v22#msg138377
#15 Publicado: 4/3/2026 20:54:46
Ted White
Ted White
0 me gusta en 1 mensajes.
I tried running the appimage in Kubuntu 24.04 running KDE Plasma 5.27.12 and X11 graphics. It loaded and presented the worksheet environment but then froze. At one point it locked up the whole system and forced me to power down.
Any thoughts?
#16 Publicado: 7/3/2026 5:21:24
Grupo: Moderator
We really can't say anything without looking some logs or terminal outputs.
