error: result is above max
error: result is above max - Mensajes
#1 Publicado: 28/5/2021 10:21:06
takeo kusumi
takeo kusumi
0 me gusta en 3 mensajes.
hi,
I'm a beginner
I get an error in the calculation
error :
result is above max. Allowed positive number
How can I solve it?
impedance.sm (34,02 KiB) descargado 1213 vez(es).
#2 Publicado: 28/5/2021 10:39:29
Grupo: Moderator
hi,
I'm a beginner
error :
How can I solve it?
Change your calculation result from symbolic to numeric.
You can do it with eval() since they are all numbers.
#3 Publicado: 28/5/2021 15:27:57
takeo kusumi
takeo kusumi
Thank you
I understand the cause of the error
#4 Publicado: 28/5/2021 18:40:26
eval() is a general rule but an absolute rule.
Many projects fail from eval(,).
SS 6179 does not complain as you constructed.
eval(,) is applied afterwards to isolate/accelerate.
#5 Publicado: 28/5/2021 20:33:21
Good application case to globalize within the program.
... in my SS 6179 timing drops from 2.6 s down to 1.6 s
#6 Publicado: 28/5/2021 20:55:57
takeo kusumi
takeo kusumi
Thank you.
I was able to calculate the frequency characteristics
(PP2.sm)
But when I modify a circuit, I get an error even with eval.
(PPS.sm)
it's very difficult.
PPS.sm (176,46 KiB) descargado 1217 vez(es).
PP2.sm (167,69 KiB) descargado 1221 vez(es).
#7 Publicado: 29/5/2021 10:50:48
Thank you.
(PP2.sm)
(PPS.sm)
... sorry, can't help: this document opens freak SS 6179.
You seem to put too much that can't be debugged piece wise.
#8 Publicado: 29/5/2021 12:11:55
Thank you.
(PP2.sm)
(PPS.sm)
Hi Takez. Yes, it's very difficult recognize or even guess where the program needs some evals. Also, putting them everywhere make unreadable the procedures. In the case of your PPS.sm that's SMath stores into Z without eval
and this with it
So, for PPS.sm there is where you need to use eval, and seems that then all other calculations works.
#9 Publicado: 29/5/2021 12:33:20
Grupo: Moderator
Razonar's is the correct solution.
Deleting my post.
Alvaro 29/5/2021 17:56:00
