1 páginas (11 elementos)
coolprop plugin problem - coolprop problem - Mensajes
I am using smath version 0.99 build 7822
and coolprop plugin 6.1.7713.14622
and I have the error in the image, you can view it at this address "https://i.postimg.cc/pVKhFJDK/Immagine.png"
how can I solve it?
Thanks in advance.
WroteI am using smath version 0.99 build 7822
That stuff is Viacheslav baby.
WASP from Katmar is not freeware, but works 5 min per session.
For else fluids, I use standard data table.
Doing so, my projects are traceable thus pass QA [Quality Assurance].
Sorry but you did not help me very much,
thanks anyway for your time.
WroteSorry but you did not help me very much,
CoolProp is supposed to work in Excel, try as offered.
It is such a huge system, unlikely compatible from Smath version to version.
2015, an Smath guru [Anonymous by respect] offered an immense work sheet.
only one did work. The remaining is all red ... [from recollection SS 5346 ?]
From design or else wrongdoing the built-in unit system should
be evaporated to avoid idiotic results.
I Consulted for years with my Ti-58/59 w/o units.
Inst_Viscosity Water.sm (43,72 KiB) descargado 1526 vez(es).
It's true, functions are not loaded. I have tested the plugin with local build. Something goes wrong when building on the server. I asked Andrey about it.
Alvaro 5/7/2021 4:33:00
Maths CoolProp_Props SpeedSound.sm (28,25 KiB) descargado 1524 vez(es).
