num2str problem with sum
num2str problem with sum - BTS issue SS-43 - Mensajes
#1 Publicado: 24/8/2013 1:42:23
Grupo: Moderator
num2str() fails to convert a sum to a string. In the sum(1) example "syntax is incorrect", in the sum(4) example "n is not defined".
Edit: This is now BTS issue SS-43
#2 Publicado: 24/8/2013 3:48:22
127 me gusta en 342 mensajes.
I confirm and add some further example.
[albumimg]284[/albumimg]
[smath 0.96 (build 4884) W7 64bit]
#3 Publicado: 20/9/2013 12:26:06
Grupo: Moderator
This is the current state. sum() now can produce symbolic results.
num2str() should provide a string corresponding to the unevaluated expression if it cannot be evaluated.
