Newbie problem - Using a range of angles inside a cosine function
Newbie problem - Using a range of angles inside a cosine function - Trying to use cos(variable angle) - Mensajes
#1 Publicado: 3/10/2012 6:41:00
jjuddgb
jjuddgb
0 me gusta en 2 mensajes.
I'm trying to convert some old Mathcad files into SMath but am stuck with what must be an elementary problem, I've looked at various tutorials but can't find a solution, no doubt due to my own incompetence.
I am defining the following variables: angle:=72 and varangle:= 0, angle/2..360
In Mathcad if I then define: test(varangle):= cos(varangle) the output of test(varangle) displays correctly in a column.
If I try the same in SMath I receive either an 'argument must be scalar' or 'fill in all empty elements' error.
Thanks for any advice.
Screenshots of Mathcad and SMath attached.
btw, great software.
Mathcad - output.pdf (26,44 KiB) descargado 996 vez(es).
#2 Publicado: 3/10/2012 7:49:27
kilele
kilele
134 me gusta en 397 mensajes.
Correct me if i'm wrong, trigonometric functions don't support arrays currently.
For now, you can do something like this.
cosinOfArray.sm (5,04 KiB) descargado 1880 vez(es).
1752 28/9/2024 14:44:00
#3 Publicado: 3/10/2012 11:09:17
jjuddgb
jjuddgb
Thank you kilele
#4 Publicado: 3/10/2012 11:31:19
Fridel Selitsky
Fridel Selitsky
520 me gusta en 451 mensajes.
You can convert the vector into a system (by w3b5urf3r_reloaded)
Regards, Ber7
https://smath.com/wiki/GetFile.aspx?File=cosinOfArray%5b1%5d.rar
Davide Carpi 3/10/2012 13:33:00
#5 Publicado: 3/10/2012 11:33:28
Fridel Selitsky
Fridel Selitsky
Regards, Ber7
#6 Publicado: 28/9/2024 14:44:50
1752
1752
0 me gusta en 3 mensajes.
did arrays appear in trigonometric functions?
#7 Publicado: 28/9/2024 16:09:41
127 me gusta en 342 mensajes.
now you can use the "vectorize" function, which you also find in the side panel, and perform the trigonometric function element by element.
1752 28/9/2024 16:30:00
#8 Publicado: 29/9/2024 22:22:50
Grupo: Moderator
An alternative to the vectorize() function is the use of index vectors.
They, however, only work if they are used in a definition.
Worksheet1.sm (5,28 KiB) descargado 1642 vez(es).
sergio 29/9/2024 23:37:00
