Unit Conversion
Unit Conversion - Change from International System Units to other derived units - Mensajes
#1 Publicado: 24/4/2022 0:34:20
CBG
CBG
78 me gusta en 312 mensajes.
Hello
Does anyone know how to change the following units in the matrix shown below?:
from "kg/s" to "t/hr",
from " kg/{'m*'s^2}" to meters Water Column ("mH2O"),
"{'kg*'m^2}/{'s^3}" to Watts.("W")
Colebrook_SI_CBG.sm (29,41 KiB) descargado 1291 vez(es).
Carlos
#2 Publicado: 24/4/2022 0:58:52
Grupo: Moderator
Hello
Possibly not with your original result matrix, if you shall use results later.
It can be shown in a table region or another pseudo result matrix.
Here is the table method.
Click to enlarge
#3 Publicado: 24/4/2022 1:46:38
Grupo: Moderator
Here is your matrix with pseudo units.
Not very elegant, but it is there.
Clickto enlarge
#4 Publicado: 24/4/2022 3:05:54
Hola Carlos. You can use matrix algebra in the unit placeholder. Here one solution.
Colebrook_SI_CBG.sm (24,74 KiB) descargado 1322 vez(es).
#5 Publicado: 24/4/2022 11:21:48
from " kg/{'m*'s^2}" to meters Water Column ("mH2O",
Hola, Carlos
Moody as stand alone.
Archivo no encontrado.Archivo no encontrado.
#6 Publicado: 24/4/2022 12:59:14
Grupo: Moderator
Hola, Carlos
Relation with what Carlos asked?
None, as usual.
#7 Publicado: 24/4/2022 17:39:01
CBG
CBG
Hello
Many thanks to Overlord for his suggestions and solution.
Muchas Gracias tambien a Alvaro por su solucion.
I also thank Jean.
Carlos
#8 Publicado: 24/4/2022 17:53:16
None, as usual.
Project is Colebrook, of which the core algo is Moody.
Read Alvaro to learn more.
#9 Publicado: 24/4/2022 18:08:40
Grupo: Moderator
Reading you in mathcad forums is also instructive.
https://www.eng-tips.com/viewthread.cfm?qid=335795
#10 Publicado: 2/5/2022 13:24:12
Ruben Sidranski
Ruben Sidranski
17 me gusta en 465 mensajes.
WOW, I feel old. I didn't even remember I was on that forum/website. Thanks for the memory...
#11 Publicado: 22/5/2022 9:36:36
Stevan
Stevan
0 me gusta en 3 mensajes.
How do I set my units so my answers are in the unit I want, at the moment the answer is being returned to Pa (Pascal) and I would prefer to have the answer in kPa(KiloPascal) or even kN/m^2.
I am also getting answers in N(Newtons) and would prefer to have them set to kN (Kilo Newton) rather.
#12 Publicado: 23/5/2022 14:17:43
Stevan
Stevan
That moment you realize you didn't save a copy of the problem :/ just redid it and realized I have a lot to learn about this program
Thanks for the welcome
Coversion Problem.sm (26,14 KiB) descargado 1302 vez(es).
#13 Publicado: 23/5/2022 18:32:27
Grupo: Moderator
How do I set my units so my answers are in the unit I want?
Your attached document is fine. Jean's computer is broken.
About your question, there is a placeholder within results.
It will appear when you select result. It appears as a black square.
You can change your desired result units by altering it.
Here is a demonstration how you can do that.
#14 Publicado: 23/5/2022 20:53:08
Stevan
Stevan
I had a feeling it was going to be something so simple, this is brilliant, thanks!
