Working with Units
Working with Units - Mensajes
#1 Publicado: 23/8/2010 19:00:11
Chin
Chin
0 me gusta en 1 mensajes.
Could I ask if there is a way to choose a preferred unit after the program has calculated it?
For eg. the default unit for force is in Newtons ('N). If we wish for this to be displayed as kiloNewton (ie., kN) - how should I do this?
Thanks.
#2 Publicado: 23/8/2010 19:28:23
Grupo: Super Administrator
Hello Chin!
From the Units implementation topic:
Best regards, Andrey Ivashov.
#3 Publicado: 7/9/2010 13:38:59
matteob8
matteob8
0 me gusta en 3 mensajes.
"Unit" it's a great feature: they are everywhere in my job
But I've a little issue: how can SMath understand when I want to express a Moment instead of an Energy?
e.i. I need N*m instead Joule J.
Thanks again for this cool software!
#4 Publicado: 7/9/2010 15:01:09
Grupo: Moderator
I did not quite understand, sorry. Do you actually want insted of J every result to give you N*m ?. What's wrong with the explanation Andrey gave in the previous post - with the picture included - how to change the unit of the result?. Just change J into N*m.
You might even define a new, say, Nm unit like
'Nm:='N*'m or 'Nm:='J
and every J unit replace with Nm unit.
#5 Publicado: 7/9/2010 16:09:22
matteob8
matteob8
Thanks Radovan for the prompt reply!
I know: it's a subtle question.
J and N*m seem equals but they are quite different: the first referes to energy, the second to an applied load.
Maybe the following link could clarify the concept: http://en.wikipedia.org/wiki/Newton_metre
In the above link they suggest to use J/rad as an alternate unit for torque but it seems that doesen't work on SMath.
How can I solve this issue?
Thanks for the patience.
Matteo.
#6 Publicado: 7/9/2010 16:40:39
maweilian
maweilian
5 me gusta en 103 mensajes.
A picture is worth a thousand words:
click on the placeholder on the right and press the apostrophe " ' " to insert a unit:
type in "N * m" (use the dynamic help to make sure you are using the predefined units):
that should give you the units you desire:
Radovan Omorjan 9/9/2010 10:05:00
#7 Publicado: 7/9/2010 18:07:50
matteob8
matteob8
Yes! It's what I was looking for!
Thank you Will!
Sorry if bothered you guys, I'd never thought that the solution would be so simple.
Br,
Matteo.
#8 Publicado: 28/9/2019 19:17:24
Juan Manuel
Juan Manuel
0 me gusta en 14 mensajes.
Hello, I would like to consult you
                                                I define a temperature in degrees Centigrade, when I call it it looks like Kelvin degrees and then I can't make a sum because it tells me they are two different units. How can I do so that the defined temperature is maintained in every calculation in the unit that defined it?
Attached image capture of the problem.
Thank you
#9 Publicado: 29/9/2019 4:22:37
Grupo: Moderator
There are many posts on the Forum about handling tempereture units. See for example this one.
frapuano 29/9/2019 8:28:00
#10 Publicado: 29/9/2019 7:46:27
Smath Unit System is ISO, °C is not ISO.
Define your user unit.
If user unit is not '1', don't multiply input by user.
#11 Publicado: 29/9/2019 9:37:54
Visit Colebrook, suggestive how to carry Engineering projects.
And recover units in the results. Each project is specific.
Please, feel free to attach your project for more doctoring.
Inst_Colebrook Pipe Data.sm (61,76 KiB) descargado 1231 vez(es).
#12 Publicado: 29/9/2019 11:30:41
Juan Manuel
Juan Manuel
thanks to everyone!
#13 Publicado: 29/9/2019 17:11:19
thanks to everyone!
... too much stuff is missing
#14 Publicado: 29/9/2019 19:03:50
ry practice ignoring unit system.
Only OK for baby stuff: 2*2=4m²
#15 Publicado: 29/9/2019 22:06:13
The difference operator is often useful.
