Beta: SMath Studio 0.99.7792 (02 May 2021) - Mensajes
Ofrece numerosas funciones de cálculo y una interfaz de usuario completa, traducida a unos 40 idiomas diferentes. La aplicación también incluye una obra de referencia matemática integrada.
La aplicación puede ampliarse fácilmente según sus necesidades. La herramienta integrada de gestión de extensiones permite acceder a cientos de recursos, tanto oficiales como de terceros, que incluyen: ejemplos de uso, complementos (plug-ins), aplicaciones basadas en SMath Viewer, fragmentos de código, traducciones de la interfaz, libros interactivos, manuales y tutoriales.
Descargar
SMathStudioDesktop.0_99_7792.Mono.tar.gz (1,45 MiB) descargado 2587 vez(es).
SMathStudioDesktop.0_99_7792.Setup.msi (2,33 MiB) descargado 5490 vez(es).
I'm facing problems for selecting and moving objects with this update.
WroteHi, Andrey!
Me too, there is a performance drop with moving or scrolling regions.
WroteHi, Andrey!
How can I reproduce it?
WroteHi Andrey!
Problems with Formatted Label.
Apparently, it occurs when both text and background color is specified with "light ..." as shown.
To overcome this issue you need to remove spaces from color name (" "). I will fix this.
Thank you!
WroteWroteHi Andrey!
Thank you!
In the meantime I've added a workaround in the plugin.
WroteHow can I reproduce it?
Cleaning "~/.config/SMath" directory and reinstalling all plugins solved the performance issue.
Possibly would be resulted same with cleaning the "Roaming/SMath" directory under Windows.
WroteWroteWroteHi Andrey!
Thank you!
This workaround will not work.
You need to change line
SMath.Drawing.Graphics.GetColorByName(color.Replace(" ",""
SMath.Drawing.Graphics.GetColorByName(TermsConverter.DecodeText(color));
This is because variable color contains value from Term where text is always encoded. While GetColorByName does not except encoded values.
In case you want to see an example: I did the same correction in the Plot Region plug-in in my latest commit in main repo.
WroteOriginally Posted by: joaobr [url=/forum/yaf_postsm70583_Beta--SMath-Studio-0-99-7792--02-May-2021.aspx#post70583][/url]Hi, Andrey!
I too had this problem.
Even after a clean re-installation, the problem still exists.
WroteWroteOriginally Posted by: joaobr [url=/forum/yaf_postsm70583_Beta--SMath-Studio-0-99-7792--02-May-2021.aspx#post70583][/url]Hi, Andrey!
Please describe in details what are you experiencing.
When I open a selection box by holding the left click, it gets stucked, so I can't select objects and move them around.
I can select objects by clicking but can't drag them.
I'm testing right now and it happens only in worsheets created in previous versions.
Problem is as shown in post #13.
It occurs for files created in latest SS also.
Sorry for the delay.
WroteIt occurs for files created in latest SS also.
Did another clean-reinstallation.
Now the problem is solved only for new files saved in 99.7792.
But not for previous versions.
Thank you.
WroteDid another clean-reinstallation.
Do you mean for documents created in previous versions ?
As far back to previous versions ?
As well I noticed that last version affects "0.98.6179.21440"
Roots (range) options => Can't be set anymore ± 2.5
... Takes integers only or set it back to integer.
That happened from downloading some Forum latest version
even if denied updating like usual !
Take care ... Jean
WroteDo you mean for documents created in previous versions ?
Yes. The last one before 99.7792.
Previous versions also. Can't remember the version number but the dates are given below.
29/05/2014
19/05/2016
27/08/2016
21/06/2018
23/09/2.18
26/06/2019
23/01/2020
Thanks.
Take care.
Can't remember the version number ...
If you open the SMath file with a text editor, the second line shows the version:
e. g.
WroteIf you open the SMath file with a text editor, the second line shows the version:
e. g.
Thank you.
