modifying tables - Mensajes
WroteI just inserted a table region into my sheet, but I can't figure out how to change the number of rows or columns, or how to type in it. I select the boxes and a popup that I don't know what to do with pops up.
Table Region Carlos.sm (12,27 KiB) descargado 1241 vez(es).
WroteI typed exactly what is in the Table Region Carlos.sm and then added the table below with the Insert Table command, and still it does not work.
Once you have inserted the Table from the insert menu,
in that 3 x 3 chess board: type Table in the place holder.
Print Screen, paste in Paint, Select, paste in a tool
that will save as *.PNG [I use WinGrab for over 20 years]
WroteWhat I want to do is produce a table similar to the image I attached:
Smath is an advanced CAS. Maybe purchase a tool to list the barn population.
What about Excel, Word ... ?
WinGrab is freeware perpetual for all Windows versions
In 3 clicks for decent image in the Forum:
attach in the Forum
Hello
This is a part of your table
Table Region Carlos_R1.sm (28,69 KiB) descargado 1220 vez(es).
Carlos
WroteAfter you produce the table in SMath, are the numbers in the table usable in a calculation? If not, then there is no point, and it is better to just copy and paste from Excel.
Obviously, you can use any element from Smath data Table or from matrix result,
just address the element as needed ... no limit.
Of course, look at the operation fixture 1.2 by fixture 1.4, which results in 4. within the same table.
Carlos
WroteWhy does my table say 1 deg F and not 30 ?
Please: attach the document so helpers won't have to redo.
Wrotetest.sm (18,91 KiB) descargado 1182 vez(es).
WroteWroteWhy does my table say 1 deg F and not 30 ?
Here is the correction. It was still necessary to define your own unit of
degrees farenheit to prevent Smath Studio from interpreting it as Kelvin degrees.
On the other hand in the table was missing include the variable Temperature
(temp) divided by the units (° F)
test _Britt1.sm (19,93 KiB) descargado 1224 vez(es).
Carlos
Jokes aside, it is probably the value in the base unit (Kelvin).
I'm sorry but I'm from mobile right now, I can't check it deeply nor provide some example, I hope some of our skilled users can help you more here.
Edit: thank you Carlos
