Definite integral - "x - not defined" ?
Definite integral - "x - not defined" ? - Mensajes
#1 Publicado: 7/2/2019 10:08:26
Conrad
Conrad
0 me gusta en 1 mensajes.
I have the following problem, trying to solve the definite integral int((3*x^3-x^2+2*x-4)/sqrt(x^2-3*x+2),dx,0,1): I get the error "x - not defined" and, of course, no result.
If I change the limits to [0..401], I get a result (!) with no error message, but if I set the upper limit lower than 401, I get the error again...
What is the reason for that?
Thanks in advance for your replies.
Conrad
#2 Publicado: 7/2/2019 11:13:06
The integrand is undefined @ x = 1
#3 Publicado: 7/2/2019 11:41:17
Three verdicts in there:
1. Nothing will integrate that freak above x=1.9999999999999999999999999999
2. Nothing will integrate up to x=0.99999999999999999999999999999999
3. Can only integrate in reasonable range of the integrand.
Interesting Classroom example ... always plot the integrand !!!
IntegrateFreak.sm (7,28 KiB) descargado 1238 vez(es).
#4 Publicado: 7/2/2019 12:32:46
Hello Conrad,
Often, it is possible to improve the Smath native Simpson integrator.
Romberg is profitable in example 2 which looks easy from plotting
the integrand, but finally is not so.
Integrate Romberg Technical.sm (51,89 KiB) descargado 1229 vez(es).
#5 Publicado: 8/2/2019 3:50:36
Grupo: Moderator
you can use maxima plugin if it is necessary.
#6 Publicado: 8/2/2019 6:33:47
Hi. I think that here the point is how to handle avoidable discontinuities in SMath. Because integral and other operators or functions not accept the 'if' statement, you can use 'cases' in the definition of f, as this:
Even this isn't the case, this other is more general for avoiding numerical issues with avoidable discontinuities:
sergio 8/2/2019 8:59:00
#7 Publicado: 8/2/2019 6:47:42
About the other discontinuity, at x=2, I guess that you don't want to work with complexes. It's usual take the absolute vale of logs and roots in real analysis calculus. This other isn't avoidable discont, but can be handled in a similar way.
discont_integral.sm (8,65 KiB) descargado 1221 vez(es).
Вячеслав Мезенцев 8/2/2019 8:30:00, frapuano 8/2/2019 9:52:00, NDTM Amarasekera 8/2/2019 12:14:00
#8 Publicado: 8/2/2019 8:33:05
1.558 me gusta en 1.868 mensajes.
Grupo: Moderator
maple() also can do that.
Archivo no encontrado. Archivo no encontrado.
frapuano 8/2/2019 9:53:00, NDTM Amarasekera 8/2/2019 12:14:00
#9 Publicado: 8/2/2019 13:34:33
maple [0..1] = -2.98126694400594
Mathcad 11 [0..1]= -2.98126694400554
Smath = -2.98126668567898 ... acc 10000
This is a case of singular end point
#10 Publicado: 8/2/2019 15:16:38
... This other isn't avoidable discont, but can be handled in a similar way.
Well, actually, the integral converges for x=2, as one can see in this wolfram result
That's means that numerical procedure for computing int in SMath needs some improvements.
#11 Publicado: 8/2/2019 16:13:59
That's an old long due request.
At least, we have the adaptive from Carlos
Romberg algo style works well, very useful too.
