Advantage of vectorize function
Advantage of vectorize function - Data Analysis Using Truth Tables - Mensajes
#1 Publicado: 6/7/2019 2:51:39
NDTM Amarasekera
NDTM Amarasekera
130 me gusta en 352 mensajes.
On the request of a fellow Engineer, the attached SM program was developed
to find the Standardized Precipitation Index (SPI).
58 years of daily precipitation data was available.
The SPI is widely used to analyze meteorological drought on a range of
time scales. There are proprietary software packages for this purpose.
The “vectorize” function was pretty handy and fast in analyzing various conditions.
SPI_cal-Rev & Improved-Final.sm (1,92 MiB) descargado 1502 vez(es).
Rainfal_Data.xlsx (486,22 KiB) descargado 1124 vez(es).
Radovan Omorjan 6/7/2019 4:23:00, frapuano 6/7/2019 5:13:00, Davide Carpi 6/7/2019 11:20:00
#2 Publicado: 19/9/2019 12:23:07
NDTM Amarasekera
NDTM Amarasekera
Attached file may be useful in handling data, where it may be
necessary to extract numerical values removing any strings, or
negative values, zeros etc.
Data Analysis Using Truth Table.sm (78,91 KiB) descargado 1456 vez(es).
#3 Publicado: 19/9/2019 12:44:46
Maybe more or otherwise in there.
Utilities Matrix Truth Table.sm (59,54 KiB) descargado 1455 vez(es).
Utilities Matrix Truth Table [UNSORTED alyles].sm (15,01 KiB) descargado 1307 vez(es).
Utilities Matrix Truth Table [Locate row_col].sm (43,39 KiB) descargado 1336 vez(es).
#4 Publicado: 13/4/2020 13:20:47
NDTM Amarasekera
NDTM Amarasekera
Advantage of vectorize function revisited.
Another practical example attached, with extensive use of the vectorize function. No loops used.
Comments by Martin, Jean, Razonar and others on this subject much appreciated.
Hope this may be useful for beginners.
Cheers
SPI_cal-Millawana_Multiple_R5.sm (178,1 KiB) descargado 1434 vez(es).
rainfall_KalaOyaBAsin.xlsx (585,15 KiB) descargado 1088 vez(es).
#5 Publicado: 13/4/2020 13:47:05
Sorry mon Ami ... SS 6179 does not open ... Jean
#6 Publicado: 13/4/2020 14:04:20
NDTM Amarasekera
NDTM Amarasekera
Sorry. PDF attached.
SPI_cal-Millawana_Multiple_R5.pdf (1,03 MiB) descargado 906 vez(es).
Davide Carpi 14/4/2020 9:24:00, frapuano 14/4/2020 11:57:00
#7 Publicado: 14/4/2020 9:04:19
Thanks for the *.PDF ... superb quality !
#8 Publicado: 12/11/2020 3:56:59
NDTM Amarasekera
NDTM Amarasekera
I have found this useful in day to day work.
Data imported from MS Excel sheet, and using "findrows" function to sum daily data to monthly totals.
sergio 12/11/2020 5:23:00
#9 Publicado: 16/11/2020 14:13:48
NDTM Amarasekera
NDTM Amarasekera
Attached is a simplified version of a project work for demonstration only.
The data file consists of date strings, and hence, had to be transformed into numeric.
Hope this may be useful for beginners. Vectorize function very useful in this exercise.
Handling DATE STRINGS.sm (16,17 KiB) descargado 1438 vez(es).
sergio 17/11/2020 14:39:00
#10 Publicado: 16/11/2020 20:48:19
The secret is inside your nice piece of work ... superb, thanks.
Take care my Friend ... Jean
#11 Publicado: 16/11/2020 23:58:06
Hi. Handling data strings you have also this cheat for convert dates to numeric matrices.
Handling DATE STRINGS.sm (20,56 KiB) descargado 1379 vez(es).
sergio 17/11/2020 14:39:00, NDTM Amarasekera 17/11/2020 22:29:00
#12 Publicado: 17/11/2020 1:41:25
NDTM Amarasekera
NDTM Amarasekera
Thank you Jean for your kind words and encouragements. Take care.
Thank you Razonar for the superb alternative. Take care.
#13 Publicado: 17/11/2020 9:44:04
You too Alvaro: take care, thanks ... Jean
#14 Publicado: 2/2/2021 4:35:43
NDTM Amarasekera
NDTM Amarasekera
Revised program to handle date strings.
Handling DATE STRINGS+Alvaro.sm (43,62 KiB) descargado 1422 vez(es).
Alvaro 2/2/2021 15:35:00
#15 Publicado: 2/2/2021 11:27:50
Thanks Collab for that most useful work.
Saved ... for future use.
#16 Publicado: 2/2/2021 15:44:06
Hi Amarasekera. Yes, that one, thanks. The fact you're showing despite to me about the speed in procedures with arrays. In the attached some comments about the need to redefining M:=M where M is a matrix argument in a procedure.
EvalTest.sm (17,47 KiB) descargado 1410 vez(es).
EvalTest.pdf (73,82 KiB) descargado 765 vez(es).
sergio 3/2/2021 6:33:00
#17 Publicado: 2/2/2021 18:53:27
Your last Speedy Gonzalez is the Smath Numerical Fairy.
As it looks, pure numerical code coincidence as a fact.
Slightly adapted for convenience SS 6179
Thanks, cheers ... Jean
Maths eval(,) TEST.sm (16,84 KiB) descargado 1398 vez(es).
#18 Publicado: 2/2/2021 19:26:52
Ruben Sidranski
Ruben Sidranski
17 me gusta en 465 mensajes.
Alvaro,
Are you showing that by redefining Mo variable, within the program, it speeds it up 30 fold? That makes no sense
The only thing that remotely comes to mind is that M, being defined within the program structure as M:=Mo, is not having to read for the variable from the outside.
Have you, or anyone else, tried this on other programs?
#19 Publicado: 2/2/2021 19:54:30
Alvaro,
Yes. Please, try to check in your environment if this is true also. (Notice that my laptop is very slow, because always is running something else or overloaded by some other procedures)
Yes. For this was the issue in the original Amarasekera work, and why I say that he was the first showing this behavior. But I have other codes where using M:=M speed up slow procedures. Actually anything with a loop over a matrix.
Here intermediate timing result, which I can't explain
#20 Publicado: 2/2/2021 22:13:47
What's wrong or incorrect in there is length it shouldn't exist in Smath
