1 páginas (4 elementos)
Lagrange Multipliers - Lagrange Multipliers - Mensajes
Draghilev is on the menu ... is it applicable in there ?
Maths Lagrange Multipliers Copy.sm (59,81 KiB) descargado 1293 vez(es).
WroteDraghilev is on the menu ... is it applicable in there ?
Hi Jean. Yes, it is ... but just give only one point, because there are only one solution. And the method requires at least one starting point ...
Drag_Jean.pdf (54,46 KiB) descargado 820 vez(es).
Drag_Jean.sm (49 KiB) descargado 1333 vez(es).
Maximization added.
Drag_Jean max and min.pdf (76,37 KiB) descargado 816 vez(es).
Drag_Jean max and min.sm (56,51 KiB) descargado 1237 vez(es).
WroteMaximization added.
Thanks Alvaro ... gorgeous solutions.
The Draghilev part persists "Syntax incorrect".
Don't worry Alvaro: You are doing so much for Smath Community !!!
Maths Lagrange Multipliers Alvaro [Maximize-Minimze] Copy.sm (23,64 KiB) descargado 1176 vez(es).
